I have checked the fuse. I have checked the extension lead in question. Water flows through the hose, the pressure washer, but there is no power on switching it on.
Could be in the spray handle and or nossle. Many years ago I brought 1 of these units ( Not by Bosch ), and the problem turned out to be in the spray handle...
Testimonial: "Thanks, do mean a blockage. I did check and the water is going through the handle and nozzle!"
First is not to use an extension lead as this will cause insufficient power to the pressure washer.
Some washers have a reset button if a power problem has caused it to trip so try to locate that and reset it.
Also try to start the machine with your hand already holding down the trigger.. perhaps there is air clogged up inside the pump.
Let us know if any of that helps.
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
check you CPU make sure its securely seated and has thermal grease
hope this helps
One bad lead or faulty connection point can cause a computer to shutdown continue on a cycle or fail to detect your hard drive boot up
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope this helps you
Thanks. The water flows through handle and nozzle...
If I am correct you are saying that when the unit is running you have " Normal water Pressure ", such as from a faucet, but you do not have power washer pressure ( pressurized water ) from the spray handle ?. If this is the case and the unit works fine, you might want to look up on line or if you have the manual and verify the causes as described
