Re: acer aspireone netbook windows xp model AOD250. reset pre-loaded system to its default state. completely lost internet connection. Formerly connected via home network. currently, in safe Mode; helplessly lost. Request simple sequential info re: data input. Want a functioning DSL AT&T 2Wire wireless/ethernet connection!
SOURCE: cannot connect to internet
try running this command "netsh winsock reset" in your dos prompt. to go to dos prompt press the window key+r and type "cmd". then it will popup a new window. type the command and see if you can connect to internet. it might be a problem with spyware as well which infected the winsock or the network drivers. download combofix and run it.see if that helps u.
SOURCE: wireless connection
Settings must have changed and not not changed back, set your friends settings as default settings. He may have accidently reset something etc.
A quick solution is to go to
System Restore and reset it back a day before you gave it to your friend.
go to START > PROGRAMS >
ACCESSORIES > SYSTEM TOOLS and you'll find SYSTEM RESTORE there. Click on it and find the option to set your Notebook to an EARLIER TIME. After selecting that from the list find a date BEFORE YOU LOANDED THE NOTEBOOK TO YOUR FRIEND and left click on it and follow the instructions and your COmputer will restore the system to that earlier date (it could be 1 day before you loaned it). You will not lose any files etc.
After it goes through a cycle of rebooting etc and it resets to the earlier date, your Network should work as it did before you loaned it to your friend.
If you have trouble finding SYSTEM RESTORE go to HELP and look for a link there.
Good Luck !
Cheers !
SOURCE: my new wirless acer aspireone d250 will not
Have you put the correct security wep key when it prompt you .you refresh the list and choose the preferred network.
SOURCE: a aspireone acer netbook keeps reading dskdrv but
try at the start up alf f10 f12 all the time until you get to recovery screen and try a factory recovery if during the recovery it run to a error just rebout and do it again a will complete sussecefull thanks and pust back if you need futher help thanks
SOURCE: Acer Aspire One Netbook wireless internet connectivity problem
Try Resetting Your Wireless Router.. turn it off then back on
then run a repair on your wireless network
