Prostart was from Pepboys around 2000-2001 but it is still working . The booklet has no contact info. It offers 580 peak amps. Can I go to Radio shack for a generic 120v ac charging adapter? I keep trying to look up online Prostart but to no avail.
SOURCE: Vec010bd AC charger part # 5140045-34 question . . .
barrel pin 12v 500Ma is correct. the only other required stat that you need to know is that the polarity is( ---------that's how the inside pin polarity is shown on the transformer. Go to any radio Shack, and they have this charger in stock. tell them you need a 120v. a/c input, 12v. DC 500 ma output, with the center (inside) pin positive( ).It should be less than $20.00
Testimonial: "Thanks RetiredRon, this was the first post I'd seen for the polarity of the plug."
SOURCE: I Lost The AC 120V AC Charger
NORMALMENTE ESTE TIPO DE EQUIPOS TRABAJAN CON UN CARGADOR DE 1000mA
SOLO BUSCA UNO CON EL VOLTAGE QUE TIENES EN CASA Y CON EL MANUAL CHECA TU VOLTAGE DE SER DE AC (CORRIENTE ALTERNA ) A CD (CORRIENTE DIRECTA) O DE AC A AC COMO LO PONES EN TUI PREGUNTA EJEMPLO DE 120V CON SALIDA DE 15VAC DE 1AMP.BUEN DIA
SOURCE: I Lost The AC 120V AC Charger need to buy
i lost mine to couldn't fined one so i found a 12v dc 1.2amp with a + tip that was on a little portable tv,it works just fine
SOURCE: 120v ac adapter for vector jump start system
Try this link. It is for the VEC012C which is sold through black & Decker.
http://www.dewaltservicenet.com/Products/PartDetails.aspx?partid=279461
