Wont shut off
That pump doesn't have a pressure switch! It has a digital flow sensor on discharge. It will keep running so long as there is a flow. Usually caused by dripping tap, or leak. Pressure doesn't stop the pump. By the way - Don't expect to get parts from Canadian Tire or Mastercraft - They told me that they carry NO parts for that pump. It is very similar to a Burcam pump and they may have parts or offer service.
SOURCE: why wont my Jet pump shut off?
Is the little pipe that connects to the pressure switch clear?
I suggest you remove it and blow through it to make sure it is clear. If the pressure is getting to the switch, it has to shut off ... your switch should be set around 30/50 (on at 30 - off at 50)
the pressure switch is bad
