Computers & Internet Logo
Anonymous Posted on May 31, 2013
Spooling error when try and print from my laptop I get the message "error spooling" and the page does not print
Anonymous
Level 3:
  • HP Master 2,878 Answers
  • Posted on May 31, 2013
Anonymous
HP Master
Level 3:
Answers
2878
Questions
0
Helped
487970
Points
8243
Right click My Computer > Manage > Services and Applications > Services > Print Spooler. Try stopping and starting. Make sure it is set to Automatic and Login is Local System.
If this is in office network, then IT needs to handle. GL
Spooling error
What make and model printer ?
There are a variety of reasons why a printer may feed a blank page through. This is, in some cases, an error. In other cases though it is a mistake in the page count or a simple matter of the printer trying to maintain itself.
Maintenance If a user has just loaded new paper into the printer or if an error message has recently been cleared the printer may run a blank page through.
Usually this is to make sure that the print path is now clear and that the next sheet it positioned correctly for printing.
Page Count
When a document is edited there is sometimes a blank sheet left at the end of the document. So, for example, if a 10 page document is edited down to nine pages, the computer and printer still sometimes read it as a 10-page document when a user hits the print key.
Page Separator
In some cases where a large number of documents are being printed, users may set a blank page separator.
This puts a blank page between copies of a document to show where one ends and the next begins.
A quick look at the printer's settings or control panel will tell you if this option has been turned on.
Fix a Printer Spool Error
When you send a job to your local or network printer, the print spooler is what keeps track of that job's location in the queue.
If the print spooler is not running, your job will not be able to reach the printer, so it is important to know how to resolve print spooler errors when they occur.
Click on the "Start" button and choose "Control Panel" from the menu.
Double-click the "Printers and Faxes" icon and locate your printer.
Double-click on the printer to get the list of jobs in the queue.
If you see any jobs in an error status, right-click on those jobs and choose "Cancel" from the menu.
Close the "Printers and Faxes" window and double-click on the "Administrative Tools" icon. Choose "Services" from the menu.
Scroll through the list until you see "Print Spooler," then right-click and choose "Start" from the drop-down list.
This restarts your print spooler and allow your jobs to print.
Right-click on "Print Spooler" again and choose "Properties" from the menu.
Go to the "Startup" option and set it to "Automatic."
This ensures that the print spooler starts each time your computer does.
Print spooler
http://social.technet.microsoft.com/Forums/en/itprovistaprinting/thread/cad5221a-d21b-4bf0-8e86-cacae254cb52
I cannot get my document printed. when i try to print I get the message printer is busy then , another message that states a printing error occurred appears
Open Notepad and type the following lines:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
Save it in your root directory as: C:\DeletePrintJobs.cmd
Create a shortcut for it and move it to your Desktop
Now everytime you have print job(s) that got stuck in the print queue
go to your desktop and Double Click on the DeletePrintJobs.cmd
It will clear all pending print jobs in the print queue and allow you to
print new jobs again.
1helpful
Dear FixYa Sometimes when I'm printing a word document contains only one page the printer prints rubbish characters or unknown symbols also beside this the printer prints these rubbish characters on a...
This is usually caused by a spooling error or more likely an error within microsoft word. I would try to make a pdf of the word document and print from that.
Printer error messsage
attempt to clear the print spool and set the its settings to print directly to the printer. Do a test print, then enable print spooling again. If the same thing happens, uninstall and reinstall the latest printer driver
Samsung clp 510
usually happens when the NIC card goes bad, may need to replace.
first try resetting the printer, look in your manual
3helpful
5answers
Printing blank pages
I am working on the same problem. While you will not like the
answer here it is for the canon mf6530. What is causing it
is the shutter over the laser is failing to open. There for
it blocks all exposer. A temperary fix is to carefully lift the
shutter and tape it open using black electrical tape. Then
try a few prints you should have an image if this is your
issue as it is mine. I do not recommending running it in
this condition very long. When I find the final answer I
will attempt to post it.
1helpful
3answers
HP Colour LaserJet 4600dn printer problem
The problem is usually caused by printing a PDF file with fonts/page size/ page formating errors which will cause the printer to display the 49.3048 error. The only way to use the printer is to POR or recycle the power and delete the print job from the server or spooling device and cancel it on the printer before the offending command is issued to the printer again. You can try updating the firmware to the latest version 46.140.5 from the HP website. MIke L.
Printer Error
check all drivers first........
if it dont work............try to print any matter........
if it work then main matter u r trying to print may be in not a printer supported format
dont forget to tell me u r problem solved or not
best regards & best of luck..
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
