How to fix code error 8600 of canon pixma MP860
SOURCE: canon pixma ip 1500
anon PIXMA iP1000
Waste Ink Counter Reset.
Step 1: Manual for Service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
step 2 : Software for Permanant
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT)
3 .Choose (SET DESTINATION 1) And it should be reset.
Remark "After service mode Pls use software for permanent reset"
SOURCE: Error 5800: waste ink
Clean or replace the absorber and reset the printer counter to clear the message.
SOURCE: my canon pixma mp830 shows error code 5010. what
The scanner lock switch may be in the locked position. Lift the cover and check the slide switch located on the top front left. If this is not the problem, you will have to have a service center look at the problem.
SOURCE: Any help with a Canon Pixma MP 250 P2 Error Code?
I found you a site where you can download the latest drivers to install at the link below Good Luck
http://support-au.canon.com.au/EN/search?canonsearch=1&lang=EN&category=All-in-One Printers&series=All-in-One Printers&model=PIXMA MP250&menu=Download
SOURCE: Canon Pixma MP145 Error Code for E22 Carriage Error.
Canon Pixma MP145 Error Code for E2,E3,E5, E15 and E16. How do fix it??
can you give your answer in my email [email protected]?because I need this soulution soon..thanks
