Sewing Machines Logo
Posted on Mar 19, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Missing tension spring screw?
I am unable to adjust the tension of my bobbin thread?
Anonymous
Level 2:
  • Expert 323 Answers
  • Posted on Mar 20, 2009
Anonymous
Expert
Level 2:
Answers
323
Questions
0
Helped
146484
Points
830
You quickest and easiest fix is to buy a new bobbin case because screws are hard to find. A new bobbin case should cost less than $20 and any sewing machine dealer should have one.
sewman7
2answers
How do to adjust the bobbin tension? Do I need to remove the throat plate and loosen the screws that hold the bobbin mechanism in place so I can get to the tension screw?
the tension screw for the bobbin thread is on the side of the bobbin carrier
that bit that you put the full bobbin in to clip it back onto the machine
t there is a small spring plate that you pull the bobbin thread under when you put the bobbin back in the carrier and you pull the thread down a slot and under that spring plate
the tension is adjusted by that small screw that holds that plate on
only very small adjustments make a lot of difference to the tension
don't touch any other screws or you will alter the needle /hook timing and that will put you a pickle
2answers
What adjustment do you need to make when the bobbin is throwing too much thread out.
Your tension is is too loose somewhere I guess, so will need tightening. Tighten the upper tension first to see if that helps before tackling the spring on the bobbin. If you need to tighten the spring on the bobbin then do it in tiny increments and remember where you started. Try taking out the bobbin and gently pulling by hand the thread from it; it should have a slightly tight feel on the correct tension..
3answers
The bobbin thread on my Juki DDL-8700 is loose and bunching up. I have messed with the tension on both top and bobbin and I cant get it tightened up. Please help!
Hello Lacinda have a good day to you concern loose or missed stitches please check next: 1-try to change bobbin case with new one. 2-check timing between needle and hook by -make needle bar at lowest position and you can see two mark line at needle bar. -bring the needle bar at second line from down side then check the flat part from needle comes with tip of hook ( if yes means timing is OK , if not means you need to adjust the hook timing . 3-check the ginger guide for hook try to move it foreword or backward to pass thread smoothly. if this is helpful OK if not please send email, i try to do the best to help. best regards ASHRAF ABOZID CAIRO - EGYPT [email protected]
How do you adjust the bobbin tension on an emerald 118
There is a screw on the bobbin case that can be used to adjust the tension. However, first I would check that there is not a thread or lint caught in the tension spring of the bobbin case. Use a stiff brush to clean bobbin case. Use a needle (or other sharp point tool), and check spring area for thread.
1helpful
How do you adjust the tension on a Bernina 180
There are two tension adjustments, which should be done with a proper set of weight gauges - top and bottom thread tension should be carefully balanced to get the best stitch formation. It is best that you assume the top tension is correct and adjust the bobbin tension to match. Load the bobbin with thread of one colour and put a spool of the same thread but a different colour on the top. Thread-up the machine, load the bobbin and sew-off a satin-stitch on max width zig-zag. In this configuration, there should be a very small 'bead' of the top thread showing along each side of the satin-stitch on the underside of the material. If there's excessive top showing, the bobbin tension is too high and if none, the bobbin tension is too low. To adjust the tension, remove the bobbin case and you will see a spring around the edge with two screws through it. One of the screws holds the spring in place and the other adjusts the tension - this is furthest from the edge of the spring and is in a small 'cup' in the spring itself. To reduce tension, turn the screw VERY SLIGHTLY anticlockwise and to increase it turn it clockwise. Make very slight adjustments and re-check sewing-off the satin-stitch every time until you get the required thin line of top showing down each side of the stitch on the underside. Ideally this should be done with Mettler Metrosene thread, but as we're just balancing against the top tension, it shouldn't matter too much provided you use a good thread top and bottom.
2helpful
How to replace the tension spring in a bobbin case?
There are two springs on the bobbin case of a rotary hook machine like the 180 and I suspect you're talking about the thread tension spring on the outside of the case - this is held on and the tension adjusted by a two very small screws. The other spring is the brake spring which is a complicated shape spring that sits in the bottom of the case and puts a slight amount of pressure on the bobbin itself. Assuming the thread tension spring has been recovered along with its two screws, it should be fairly self-evident how it fits back onto the bobbin case - the spring lays across the **** in the bobbin case, through which the thread is pulled, so that the tip of the spring with a small right-angle bend just sits down into the aperture where the thread comes out. Now, importantly, the two screws are different sizes ... the one with the smallest head holds the spring onto the bobbin case and is screwed-down firmly through the hole in the flat end of the spring. The larger screw adjusts the thread tesnsion and is screwed through the hole with the slight conical sides. Now the tension should be adjusted to 5g using a proper gauge, but failing that, insert a bobbin loaded with a thread such as Metrosene and thread the bobbin case up. hold the end of the thread so that the bobbin case hangs on the thread - it should not move/unreel itself. If it does, adjust the tension screw (the bigger one) a little bit at a time until it doesn't unwind. The approximately correct tension is obtained when the bobbin will only unreel when you **** the thread upwards gently. You can fine adjust the tension to get the correct balance by ensuring the top tension is set to normal (red line) and adjusting the bobbin tension until the stitch lays properly in the fabric - use different colours top and bottom to check this. Be aware that the bobbin thread tension varies quite alot with only a small rotation of the adjusting screw, so take it is small steps.
Hope this helps.
I have a VX1250. I don't know how to regulate the tension.
There is two places to adjust thread tension: the top tension device controls the top thread tension and is usually a dial or knob with numbers on the front of the machine.
Then there is some form of tension device on the bobbin; in your case I believe the Brother has a removable bobbin case with a tension spring which holds the bobbin thread firmly: the tension spring can be adjusted with a screwdriver but once set, you shouldn't need to adjust this much, just alter the top tension slightly for different weights of fabric. So start by setting top tension dial to 4-5 and test stitch a seam. Use different coloured but the same type of thread top and bottom and take a look at the seam. You want to see a balanced even seam.
Here is a link to a great info site for this:
http://www.sewusa.com/Sewing_Machine_Repair/Thread_Tension_Settings.htm
If the bobbin thread is too loose, then you probably will need to finess the tension spring on the bobbin case and adjust this slightly. The best way to set the tension on the bobbin case is as follows. Load the bobbin into the bobbin case and pull the thread tail into the tension spring, then suspend the bobbin by holding the thread tail up in the air (the dangle test). You want it to be just tight enough to hold its own weight, but still able to release thread when you pull gently downwards on the bobbin case. If it isn't doing this then take your little screw driver and adjust the screw on the leaf tension spring by ONE QUARTER TURN ONLY. Lefty looser, Righter Tighter. Then test again, and adjust again until its right.
Now test stitch again and finess your top tension to get the seam even. Remember to change the needle for each new sewing project too; this will impact tension also.
1helpful
I have a singer 4538 and the top tension is ok, I believe. The bobbin tension is too tight. I took out the bobbin case. It has two screws. The one on the left can be loosened, but doesn't help the...
one screw should stay tightned .. the other is the adjustment ... you will notice that the correct screw is adjusting the force on a flat spring .. that spring is what provides the bottom tension .. when the thread is properly positioned then it will be pulled under that spring .. you should be able to pull the thread with just a small amount of drag .. the top tensioner should have about the same amount of drag when set to about 2 of its adjustment range .. usually the foot has to be down to engage the top tension ... you normally dont need oil on the bobbin case .. the screw you want is about in the center of the flat spring ... if you cant adjust the bottom tension then take the flat spring all the way off and see if there is thread or debree keeping it from operating properly .. make sure there are no sharp edges or burrs in the thread path ...
Husqvarna viking, interlude 435...unable to solve tension problem
Sounds like the tension unit is at fault. First check the bobbin tension by removing the bobbin case. Use a half-full to 3/4 full bobbin. Be sure it is threaded through the bobbin case with thread hanging straight down with tension spring on top. Tie the stitch plate to the end of the thread. If the thread pulls the bobbin out, the bobbin tension is too loose. If it does not move when "jiggling" the bobbin, it is too tight (which is not likely based on your description). Small screw (through an open hole) on the side of the bobbin case adjusts the tension of the bobbin case. Left for loose and Right for tighter. Otherwise, contact local authorized Husqvarna Viking dealer for their assistance. You can find the closest dealer at the Husqvarna Viking website - http://www.husqvarnaviking.com/us Good luck.
1helpful
Unable to get bobbin to pick up thread from needle.
Check the thread coming out from the bobbins maybe on reverse side,also check the bobbins tension adjust it there is a small adjusting screw.Check also the needle alignment lastly check the upper tension from the tension regulator knob,tension adjustment is depend on the fabrics that you sew.
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
