SOURCE: LG front washer WM1814CW error OE
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
SOURCE: OE error code will not go away. I have cleaned the drain plug and the drani filter
Unplug the Unit. Wait a Minute and then Replug it in.
SOURCE: my lg wm1814cw has a code of OE witch says to
You probably have an object in the pump or a bad pump
See page 27
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Here is a tip that I wrote about the LG OE Code and the causes and fixes...
Here also is the complete list of LG Codes
heatman101
