D-Link DIR-600 Router Logo
Anonymous Posted on May 22, 2013
Pin number trying to connect my router with laptop but its saying that pin code is wrong, im writting exactly the same number that is on the router but its still not working, what can i do?!
Anonymous
Level 3:
  • D-Link Master 32,281 Answers
  • Posted on May 23, 2013
Anonymous
D-Link Master
Level 3:
Answers
32281
Questions
Helped
7907837
Points
102259
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, open the browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
You can now change the default admin password.
You can now configure the wireless settings. (SSID, WPA or WPA2 encryption to protect your wireless network and Internet from unauthorized access).
Now configure the wireless card in your computer/laptop with the router's wireless settings.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
1 Related Answer
Anonymous
  • 1383 Answers
  • Posted on Jun 05, 2009
SOURCE: connection to a new laptop
first connect your router to laptop with ethernet cable.
Then u can access it with following link
http://192.168.1.1 or
http://192.168.0.1
then type user name as "admin" and password is "admin" or blank or "password"
then u can see configuration of your router.
then check its ip range and enable dhcp and also if there mac security u have to add your mac adrese in allow list
u can find your computer mac adreses with command prompt.
type "ipconfig /all" in command prompt.
then u get alL ADRSES physical adrses is your mac addreses.
Windows laptop says netgear security code is wrong
http:.//routerlogin.net user name : admin
password: password, look for wireless setting, next , look for security option choose wpa-psk, choose passphrase.
this will let you choose more simple pass key
4answers
I can't connect using my wireless... but when I connect directly to the modem I can get internet access. It keeps asking me for a pin number and I have no clue how to set it up. Please advice on what...
Hello ...
are you already check the router>?below router to find password/pin code
it have their pin code there.
Step 1:
Flip the device over.
Step 2:
You should find the model number on the sticker underneath the device. See the image below.
NOTE: Take note of the exact model number and version of your Linksys device. In this example, the model number of the device is WRT54G v5.
Step 3:
Check the serial number which is located right underneath the model number.
NOTE: The images may vary depending on the model number of your Linksys product. If there is no version number beside the model number it means the device is a version 1.
you get it number?
then try again connet with it and enter the pin code same like you get from router
<click here for instruction to setup your router>
My laptop usually has no trouble connecting to a wireless router. I have just tried to connect to a friend's Belkin *which is not locked" and it asks me for a pin code - got the pin code of the bottom...
To connect to the network in your laptop without entering a PIN code, please follow these steps.
1. Connect the computer to the router with an ethernet cable in one of the grey slot in the router.
2. Open up internet explorer and clear the address bar and type in http://192.168.2.1 and hit enter.
3. You will find a belkin router setup page, In the left hand side under the heading Wireless click on Wifi Protected Setup
4. When it asks you for a password leave it blank and click on submit.
5. There change Wifi Protected setup to disabled and click on apply changes.
6. Then in your laptop connect to the wireless network without any PIN number.
Thanks in Advance!
With Regards,
Prema.
The internet guy was just here today in my new place but i wasn't here with him.To connect to the internet it is asking for a 8 digit pin code located on the bottom of the router. I can seee several...
When you say, "IT is asking for..." exactly what is "it?"
It sounds to me like you have a Linksys wireless interface (possibly USB) on your PC which assumes it is going to connect to a Linksys router, which would have that PIN code on it... but you don't own a Linksys router and therefore the whole PIN code protocol is futile.
Bypass the proprietary PIN code nonsense and enter the WEP or WPA password the installer gave you (if any; it's possible he didn't set any) to connect to your access point from your PC.
I have two laptops and want to set up a wireless network. I have the wireless set up but it isn't secure. When I go in to the Homegroups page it asks me for a 4 or 8 digit PIN number found on the router....
If you don't know it, you won't be able to automate your Wifi Protected Setup (WPS). The pin is a very specific way to prevent yourself from always having to remember codes, keys, passphrases, etc. Without it, its like saying that you want to to connect to Bank of America, and that it's just okay because you want it to happen.
The following is taken from the ESR-9753 manual:
- Wi-Fi Protected Setup (WPS)
WPS is the simplest way to establish a connection between the wireless clients
and the wireless router. You don’t have to select the encryption mode and fill in a
long encryption passphrase every time when you try to setup a wireless
connection. You only need to press a button on both wireless client and wireless
router, and the WPS will do the rest for you.
The wireless router supports two types of WPS: WPS via Push Button and
WPS via PIN code. If you want to use the Push Button, you have to push a
specific button on the wireless client or in the utility of the wireless client to start
the WPS mode, and switch the wireless router to WPS mode. You can simply
push the WPS button of the wireless router, or click the ‘Start to Process’ button
in the web configuration interface. If you want to use the PIN code, you have to
know the PIN code of the wireless client and switch it to WPS mode, then fill-in
the PIN code of the wireless client through the web configuration interface of the
wireless router.
1helpful
2answers
WHAT IS THE DIGIT NUMBER MY D-LINK DIR-615 ROUTERS?
if you are referring to the wireless security passcode pin number , its usually written on the bottom of the router.
Im trying to find my belkin pin number so i can have internet in my new laptop,...where can i find this?
Are you trying to connect to the wireless network on a WINDOWS VISTA / 7 computer? Sometimes on the windows vista computer , it will ask you for the PIN number when you try to connect to the wireless network. On the same window at the bottom you will find the option " I want to connect to the network or I want to enter the key manually". If you click on that option , it will ask you for the security key.
If you don't know the security key, then you will need to check the settings of the router. You will need to open the router set up page where you can check all the wireless settings of teh router. If you want, you can also find the PIN on the wireless settings page of the router.
If you are trying to connect any other wireless device to the network and it is asking you for the PIN then you will need to open the set up page of the router and under wireless settings you will find PIN.
Click here for step by step instructions
2answers
I have linksys, may itouch wont connect to the internet with it
I had exactly the same problem with a brand new 3rd gen iTouch. It showed it was connected to the network but wouldn't access anything (invalid argument etc). I tried everything but no joy. Eventually I fixed it by changing the router's encryption from WEP to WPA2-PSK. Fixed it like magic. Where there had been no router or DNA data before, they were suddenly filled in. The key was different but was still on the bottom of the router. I had to re-enter the key on my wireless laptop2_bing.gif but that was a small price.
You can get into the router set-up page through your web browser. I found a guide on You Tube.
Cant connect my laptop wirelessly...
Try to reconfigure your wireless network on your DI-524.
To access the configuration page of your router by Default type in on the address bar 192.168.0.1. On the login page by default the Username is admin and leave the Password blank.
If inside the the configuration page of the router
>Click Home
> Click on WIRELESS located on the left side and you will have the wireless setting of your network
> Change the wireless network name
> Under security choose either WEP or WPA -PSK for this type of router.
> Type in your new network key (also know as Passphrase of Key1).
For WEP use 0 to 9 Number or A to F character and it should be exactly 10 characters.
For WPA-PSK you can use alpha numeric from 0 to 9 and from A to Z. The minimun character would be 8.
> Click on apply
> Click on continue.
Try accessing your wireless network first using your wireless computer. If you are connected to your wireless network try connecting to the Internet.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
