When I connect to satelite, the picture is only in B&W - I can't figure out what settings to change! When I used HDMI it's fine, I've tried 3 sets of cables, both AV inputs and it's always the same, grainy black and white. I've hooked up the satelite to another tv and don't have problems - surely there's a setting I can change? what is it?!
SOURCE: Unable to display HDMI Input
Okay so you have the HDMI cables from both the DVD and the Cable box plugged into the reveiver?
SOURCE: Connecting LG 50PC3d to Computer
It sounds like you have the resolution of the PC set to an incompatable format for your TV.
SOURCE: PS3 not working on reg tv's after HDMI use on LCD HD tv
Shelley, the fix for this is simple! Hold down the power button for about 5 seconds and the system will beep. This resets the video setting for your ps3 from HD too whatever the current cables are that you are using too hook up too the tv. This works on my PS3 which I just bought about 3 months ago and should work with the older ones.
SOURCE: LG tv shows av inputs as black & white
you need to plug all three colors in not just yellow
red blue green need to be pluged in their respective colors
SOURCE: No picture or response - LG LCD TV
Hi, I have the exact same problem. I was wondering if you could tell me how you fixed it? Mine is only 2 hours old from the box
