I have this JVC ....I just purchased the AppleTV... plugged it in and I got a picture but no sound. Neighbor came over to show pictures off his iPhone on my TV then heleft and now I cannot get anything but a green screen. Is there a setting that I need to change in order for my Apple TV to work again.
SOURCE: Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
SOURCE: JVC TV TROUBLE
If you guys do not have hand soldering skills or know how to use a multimeter, I would suggest to replace the whole assembly.
If you know how to solder you can just replace 2 ICs that are mounted on the big black heatsinks and possibly 1 or more resistors.
Click here to find the entire assembly for your TV.
The link provided is for parts for the AV-56WP74 model ONLY. For the 65 inches; you should contact the vendor and provide the correct model number.
Good Luck.
SOURCE: no sound on my 52in jvc tv
i unplugged my tv and when i turned it back on had picture but no sound and all cards are still in tack.
SOURCE: JVC I'Art. 65" projection TV. AV-65WP74 green screen sages real low.
I had the same problem that required a $400 technician fix. 1st time i tracked it to a $0.05 resistor blown. could not find in radio shack... was due to bad "brain".
SOURCE: Hooking up Xbox 360 to JVC TV 20 inch 1 year old tv from Luxembourg
change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
