Question about Drills
Makita Dc18rc from 110v to 220v
Could anyone help me in modifying makita DC18RC from 110v to 220v..... Many thanks
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Mine I just converted to 220v and it works and since i just converted it will charge quickly too as i observed
Posted on Aug 19, 2018
Did Someone Succeeded to Change the DC18RC from 110v to 220v ??
What are the component that should be replaced ??
Where can i get them ?
Thx ,
Lio
Posted on May 12, 2014
2 Suggested Answers
6ya staff
SOURCE:
ttenterprise
ttenterprise
SOURCE: Ihave 110 volt makita dc18rc battery charger,
I had the exact same problem. I ordered the ZNR V10 241U part from Dija Key. They are around 36 cents if you buy 10 of them. I cut the old one out and soldered the new one in. I changed the fuse over to an automotive one so the fuse is easier to obtain. I plugged it in and charger works fine.
What happens is a voltage spike either low or high gets recieved by the charger. The fuse appears to be slow blowing and does not stop the spike in time. The spike is stopped by the varactor surge supresser. In doing so, it saves the circuit board so all you have to replace is the fuse and the surge surprsser.
Posted on Dec 24, 2012
Makita DC18RC 110v converse to 240v
Buy one of those European adapters. If you want to convert to 240V for US current, don't do it. You'll fry that drill to a crisp.
Aug 31, 2014 | Drills
Why does my charger flash but not charge
Most chargers have a specific sequence of flashes to indicate whether it is chargers or there is a problem. If mine flashes real fast the battery is usually too hot to charge. You did not say what brand or model you have. The best way to determine if its a bad battery or bad charger is to try charging a known good battery. Usually it is the battery but occasionally the charger can be the culprit.
Aug 24, 2014 | Drills
How do i convert a makita charger model DC18RC at 110 volt to 240 volts?
The DC18RC are most likely to charged the BL1830 battery, which is the most popular of 18V Makita power tools. It is a Li-ion battery.
And the DC18RC battery charger has two volt 110 Volt and 240 Volt.
The 240 Volt DC18RC charger can replace model DC18RA & DC18SD because of its improved performance and full compatibility with Makita's NEW 'Star' labelled batteries that communicate between the tool, battery & charger. And, it is a fast charger.
It can charge a Makita BL1830 Battery in approx 22 minutes.
But, I do not recommend to convert a makita charger model DC18RC at 110 volt to 240 volts.
The reason is as below:
1. This will void product warranty ! If you follow this mod, you do it on your own risk !
2. There are several comments that described
same model # but with different design and components.
Please beware that this mod might not work on your charger
or worst, will damage it.
Only perform this mod if you know your way around with electronics !
Sep 20, 2013 | Makita Drills
Modifying the DC18RA from 220V to 110V. how?
Really, this is not something that can be changed easily, just buy a 110 charger...
Mar 14, 2011 | Makita 18V LXT Lithium - Ion Cordless...
I have makita bl1830 battery 18volt it works fine but will not charge, charger lights flash red and green therefore battery will not charge
If both red and green lights are flashing after you put the battery on the charger, the charger is reading the battery as bad or defective and it will not charge the battery. It may be because there is a short in the battery, one of the cells is bad or the battery is just old and won't charge anymore.
Feb 01, 2011 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Ihave 110 volt makita dc18rc battery charger, component VDR101 has burnt out beyond recognition and I was hoping someone could tell me exactly what it is so I can replace it. Thanks
Nov 26, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Modifying the DC18RA from 110V to 220v
Hi there the solution for how to mod a DC18RA charger can be found here. The "how to" comes with pictures and descriptions and it should be easy to follow, and best of all it works :)
Jun 27, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Drills Logo
2,110 people viewed this question
Top Drills Experts
Marvin
Marvin
john h
Are you a Drill Expert? Answer questions, earn points and help others
