Hitachi DZ-HS300A DVD Camcorder Logo
Posted on May 16, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Application Software Im having problems dowloading my application softwatre to my Windows Vista laptop, i have the disk but laptop wont read it any ideas? im only trying to upload some photos
Parshiv Luthra
Level 3:
Master:
  • Master 395 Answers
  • Posted on May 16, 2013
Parshiv Luthra
Master
Level 3:
Master:
Answers
395
Questions
Helped
86416
Points
1069
Try to download the software from the company website.
1 Related Answer
A
Anonymous
  • Posted on Jun 16, 2008
SOURCE: Neither Vista or XP will recognize the miniDVD's from my camcorder.
You have to finalize the disc in the camera before you can see it on your PC.
Automatic shutdown installing application or another software
Do not install the application any more it is not compatible with your computers Operating System it is to put it in perspective, throwing it back up. So I would make sure it is compatible for your operating system. Otherwise you may cause some damage here. Blue screening if install a bad disk or bad driver. Or software that is not 32 bit or 64 bit depends on what your computer has for a Windows system. What is the program and what is your Windows Operating system Win 7 XP or Vista. What is the model of your laptop. What are you trying to install when this happened to you? John
tip
Run your Windows xp Software on Windows 7 and Vista
Are your software not compatible with Windows 7 and Windows Vista?
Do you need to install driver from Windows XP to Windows 7 and Vista?
Here is how you do it. ^^
This is just a simple trick to show you how to run your installers and software to your Windows 7 and Vista.
Steps to run incompatible application to Windows 7 and Vista:
729dcf7.jpg.
1. Go to the installer/installed application
2. Right click the .exe and click properties
3. Click the Compatibility tab
4. Check the Ru n this program in compatibility mode for:
5. Choose the Operating System you like (most probably it will by Windows XP)
6. And try running the software again.
on Jan 24, 2010 • Computers & Internet
1helpful
Application not found,txt IM invisible
I believed this isue occurs because the IM application was not properly installed or corrupted or either the operating system of your PC is corrupted as well, so i suggest to manually install again the IM application on your PC and if it doesn't work reformat your operating system by installing the orginal disk driver again (ex. Windows xp, vista, windows 7).
you can go to www.download .com to download IM apllication
I have webcam labelled creative vista but unfortunately the CD to install it is not working.. how can i install this camera on my pc
The driver for Live! Cam Vista IM (VF0420) can be found here:
http://support.creative.com/downloads/welcome.aspx?nLanguageLocale=1033&nDriverType=1#type_1
File Name : LCVA_0420_DRV_LA_1_01_01.exe This download contains an improved version of the driver for Creative Live!® Cam Vista IM. It adds support for Microsoft® Windows® 7. For more details, read the rest of this web release note.
Requirements:
  • Microsoft Windows 7 32-bit or 64-bit, Windows Vista® 32-bit or 64-bit with Service Pack 1, Windows XP Professional x64 Edition, Windows XP with Service Pack 3
  • Creative Live! Cam Vista IM
Notes:
  • To install this driver
    1. Download the LCVA_0420_DRV_LA_1_01_01.exe file onto your local hard disk.
    2. Double-click the downloaded file.
    3. Follow the instructions on the screen.
You may also choose to install the updated application file
I would strongly suggest you consider using the Creative AutoUpdate features which can be accessed on the above page.
1helpful
When i try to run an app i get the message not a
1. It's the main problem with Vista! It don't support applications / softwares which are 16-bit (Only 32-bit applications are supported!).
2. It hardly support any application older than Windows XP (which runs on Windows 95/98/NT/Me)!
3. Try to download the updated version of your applications from internet which are Windows Vista compatible.
4. Then install these updated versions.
tell me if it don't works...tc! :)
2helpful
Cd rom wont write to disc,can this be fixed?
Its not a terminal problem but an issue with your CDWRITER or the application you use in performing CD Writing
CHECKLIST
1. Make sure you are using a Blank Empty CD
SOLUTIONS
1. Try formating the Blank disks from Windows Explorer and not from the utility software
2. Check your CDWRITER settings (usually problems do not arise from here) you could set the settings default.
Are there any error messages when trying to write data on the CD?
Missing wininet.dll no disk
probably u are trying to reinstall the same windows program that is damaged and is still in the cpu. find another windows disk and dowload this from "bios" (select the option "download from cd-rom") this will totally reset yr hard disk and all yr data and settings will be lost
Can i have a copy of the LG pc suite installer?
LG Software Updater Application Download You have to install LGMobile Updater Application before download manual, software or lastest firmware for your phone.
Please check up whether your PC can support the following requirement.
  • 1GHz or higher Pentium-compatible processor
  • At least 256 MB of RAM (memory)
  • Windows 2000 (SP4 or later) or Windows XP (SP1 or SP2), Windows Vista
  • Administration rights on the PC for software installation
  • High-speed Internet connection
http://uk.lgmobile.com/web/web.product.manualSoftwareRF.laf
STEP 1Country & Language When you install the Updater application, the Country & Language settings are automatically updated according to the user's PC information. 1.jpg 2.jpg STEP 2Manual & Software search This program searches the manual and software for your phone. Select “Application, Manual & USB Driver Download…”.3.jpg Enter a value for “IMEI/ESN/MEID” or “S/N”, and then click the view button on the right. 4.jpg STEP 3Manual & Software Download Download and use the manual & software in the list. Double-click “Manual” or “software”, which is displayed in File List, and download it to your designated location.
※ N.B.: Make a note of the download location. 5.jpg
3answers
Acer orbi cam not working
I think ur laptop webcam driver not installed properly.If ur laptop have windows vista operating system then do these steps.
Goto Start - Programs - Recovery Manager - Recovery Manager.In that recovery manager,click on next.Its shows the Software reinstallation page.Click on next button two times.Its shows the software lists.Select the webcam software and click on next button.After reinstallation completed , u restart laptop and check it.
If ur laptop have windows XP operating system then u uninstall the webcam software through Add/Remove program and restart it.After restarting ,Reinstall the web cam software and check it. If u doesnt have webcam drivers then u go for nearest service centre and install it.
Thanks
Im trying to get into pogo
The game/software you r using might be incompitable with vista!
you must try following
1st right click on the application then click on run as Administrator if you have administrative account on your pc.
or else try this
1st right click on application then click on compatibility menu then from there select windows xp sp2 then it will run.
Top Hitachi Video Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
