My ricoh aficio 2015 copier displays sc:542 error message on the screen. how do I resolve this fault?
Error SC 542 indicates a fuser temperature problem. Once the error is detected, the printer is toast until you manually clear the error from the keypad. Even though the printer is physically fine, it won?t come ready until the prior error condition is cleared. The magic keystrokes, clear the error code: The Fix In order to clear error SC542, you must perform procedure 5810. Press and hold online + escape, then power on. Use up and down arrow keys to select SP2 Press Enter Use up and down arror to locate SP5 Press Enter Use up and down arrow keys to select 810 Press Enter Confirm the selection Power off and on. The error code is now cleared.
If this code comes back after cleaning, you may have to remove the fuser cover and check the thermistor for a build up of toner. Usually when you have this code you have a worn out fuser roller(teflon coating is damaged or gone). It will have to be replace to correct the problem.
Very helpful. thank you
SOURCE: sc 542 error code
press clear (yellow) and press 1,0,7 and press and HOLD the stop button 5 secs. (red) press 1 when u see the copy sp mode and press 7 (datalog) and press ok, look for the sc/ jam counter reset. press the execute 2x. turn of the machine in the main switch (orange switch on the lower front side) the shortcut mode is by pressing 7807 na press execute
sc552
this machine is giving me code error sc:552 and is not letting me do any thing please can you help
I HAVE AFICIO DSM 415pf and it is showing ERROR SC 542
The relay was clicking and the power was as if it was small i shorted the relay the power came on and an error massage of SC542
my ricoh aficio 2015 copier displays sc:542 error pawr off on
ricoh aficio sp 4100n
my ricoh aficio sp 4100n copier displays sc:542 error message on the screen. how do I resolve this fault?
On the Ricoh Sp 100 sf e wher is the online and the escape buttons
error code sc 400 copiers page
i need to reset sc 542 error code?
how to fix Service call - SC 545 on RICO C242SF
