Some of the newer TV's dont turn on if there is no input signal. Try a DVD player and see if that works. If it does, then the issue is most likely with the cable jack on the TV, which may need to be replaced..
This tv is a flat LCD tv wright?Not a big bulge back CRT tube tv,If this is CRT tv is analoge design tv dosen't have freeview Digital Tuner inside of the tv.If it is a flat LCD tv.Make sure ur setting for retuning not on CALBE SETTING.Make sure ur tv setting are AIR SETTING and have good Digtial antena will get a stronger signal get all the free AIR broadcasting stantoins channels,a good strong Digital antenna design does make big a different.
You Can Not Change. The TV Recognize the signal on the INPUT.
If the signal is 480i than the tv shows 480i
If the signal is 1080p than the tv shows 1080p (if supported)
If you try with your areal antenna (for now digital broadcast is maximum 1080i (in USA) The TV itself doesnt "upconvert" lower resolution signals.
