After correctly connecting, installing and registering the driver disk, I went to use my scanner to scan a picture into A My Document folder (which was empty).
The machine seemed to be scanning the photo, but then stopped and I received the above error message.
Anyone know the solution to this problem?
I had a similar problem (error Code:2,140,2) in Canon PIXMA MP250 all-in-one, and it was solved when I replaced both ink cartridges which were in low ink (almost without ink). I know an scanner problem is not supposed to be in relation with ink or printer problems, but that's the way I've fixed it. Good luck!
My scanne sais iff I am drying to scan documents error 2,140,0 Scanners driver will be closed, Why?
I brought an alternative cartdridge, but the contacts were not well, so i had to buy an original Canon cartdridge to resolve my problem.
i have exactly the same problem ...the scanner of my printer wont scan any document or picture,,,and display the message erro.....the weird is that it makes copies,so when not using the pc to save scanned documents,it can scan and print(i've no problem with printing service)
think that You might to redownload your scanners sftware from CD record iff You have this!
