Question about Mtd Garden
Motor shuts down sudden after 15 to 20 minutes run
Yardman 46" mower with Brigggs and Stratton engine 17HP
2 cylinder 4 cycle Mod 42A707.
This turns off abruptly after running for 15 to 20 minutes
  • 472 Answers
It could be 2 things the soilonod is bad or the jets are pluged up in the carb
Posted on Nov 08, 2013
6ya staff
SOURCE:
Anonymous
  • 1847 Answers
SOURCE: Briggs and Stratton 17HP Intek Governer Overspeeds
Can you Regulate the Engine Speed Using the Governor Arm? If Yes, then Reset the Governor. **To Reset the Governor; Loosen the Governor Arm Bolt and Turn the Governor Shaft Clockwise Until it Stops. Using the Governor Arm Hold the Carburetor to Full Throttle. Now with the Shaft Full Clockwise and the Governor Arm and Carburetor Held at Full Throttle, Tighten the Governor Arm Bolt. If the Engine Still Runs Full Throttle, then Reverse the Rotation of the Governor Shaft, but Still Hold the Carburetor at Full Throttle with the Governor Arm. If it Still Runs at Full Throttle, then Check the Internal Governor.** If you Can Not Regulate the Engine Speed Using the Governor Control Arm, then Check the Carburetor Throttle Valve. If the Throttle Control Valve (sometimes called a Flap or Plate) Mounting Screws Came Out of the Control Valve, then you will have No Control Over the Engine Speed. Send me the Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you. **The Throttle Cable Attaches to the Throttle Control Bracket. The Cable Moves a Slide that Moves a Pivot. The Pivot has the Spring Attached to it and to the Governor Arm. The Solid Link Connects to the Governor Arm and goes to the Throttle Shaft on the Carburetor. When the Throttle Cable is Moved it Moves the Pivot and the Pivot Pulls the Spring. The Spring Pulls the Governor Arm and the Governor Arm Moves the Throttle Shaft. Usually the Spring is in the Lower Hole in the Governor Arm and the Solid Link is in the Top Hole of the Governor Arm.** If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens
Posted on Sep 24, 2008
Anonymous
SOURCE: I have a 17HP mtd yardmachine riding mower. the
MTD HUFFY 15HP BRIGGS
Posted on May 23, 2010
damnor01
damnor01
  • 1179 Answers
SOURCE: 17hp ohvfitted to ariens 1742
The oil is passing the rings on the pistons and is therefore being burnt in the ignition process. In the combustion cylinder.
The valves may also have been bent in the process, one would need to check these to get the engine to run well again. Any bent valves will cause a loss of power.
Take care!
damnor01
Posted on Apr 28, 2011
jesusismy138
jesusismy138
  • 8 Answers
SOURCE: riding mower with 26hp briggs and stratton motor runs about 20 to 30 minutes thens cuts out
It sounds electrical in nature check the solenoid for continuity, check your key switch it may be bad also, check the spark plug wires and the part they hook into. Look for melted wires and replace as needed.
Posted on May 11, 2012
jerryblakesl
jerryblakesl
  • 29 Answers
SOURCE: my briggs and stratton twin
I would check the deck ( while engine NOT running) to make sure there is no binding from any of the idler pulleys or from the mandrels...
Posted on Aug 09, 2012
Briggs and Stratton 17 HP Riding Mower
Hi Lawrence.
There should be a few more numbers/ letters to your model number. I added a link to a website for you to check out. Click the link or copy and paste it. Hope this helps.
https://www.repairclinic.com/Shop-For-Parts/a22b303d782009/Model-42A7072653E1-Briggs-Stratton-Small-Engine-Parts
May 30, 2017 | Briggs & Stratton Garden
Mtd yard machine mod#42A707 flywheel
Your probably will looking an used replacement on Ebay. Also you should use the complete engine info to look-up the correct flywheel but is the most common flywheel. Covers about 150 versions of the 42A707 series.
Flywheel 691976 for Briggs and Stratton Lawn Equipment eReplacement Parts
Feb 11, 2015 | Mtd Garden
17hp briggs and stratton blowing oil out of dipstick
looks the rings are stuck.when you have head off check piston. john.
Mar 10, 2014 | Briggs & Stratton Garden
Need valve clearance on Briggs eng. Mod. 407777
Set No. 1 cylinder at 1/4" past TDC (Top Dead Center) on compression stroke. Gap both valves at .005". Gap is set with the engine being cold. Do the same for the other cylinder. Be sure to lock the adjusters back in place.
2. .S
Aug 07, 2013 | Briggs & Stratton Garden
Is my riding mower engine seized?
remove the cylinder heads see if the pistons are moving fro disc doesn't sound hopeful
Apr 04, 2012 | John Deere Garden
What type of motor oil does a yardman mower 12a-268n755 use?
Hi, if it has a Briggs and stratton engine it uses 4 cycle sae 30 motor oil. Hope this helps, regards Phil.
May 24, 2011 | Mtd Garden
I just want an owner's manual for briggs and stratton engine Model 42A707 Type 2238 E1
http://www.briggsandstratton.com/engines/support/operators-manuals.aspx?NTT=42A707-2238-E1
Should fix you right up.
Oct 05, 2010 | Garden
Part # needed
most B&S 17HP Take the same starter up to 20 hp single
Jan 22, 2018 | Garden
B&S 18HP ENGINE WILL NOT START WHEN HOT
Could be valve hanging, need to check compression when hot.
Sep 20, 2017 | Garden
Garden Logo
156 people viewed this question
Top Mtd Garden Experts
dannydoesita
Joseph Mueller
Joseph Mueller
p38arover
Level 1 Expert
Are you a Mtd Garden Expert? Answer questions, earn points and help others
