Question about LG 32LG30 32 in. LCD HDTV
Lost freeview channels after cable unplugged
We've only had the TV for a week and its been playing freeview from the wall aerial cable just fine. Cable got unplugged by cat and now the TV wont pick up any freeview on retune. Have tried factory reset with no luck. Have tried retuning without cable plugged in and then retuning with it plugged in again, nothing. No BBC, etc. Please help!
  • The Dame May 04, 2013
    Never mind, mom plugged it back into the wrong socket!
    Top Expert:
  • LG Master
  • 76,177 Answers
Sounds like tuner fault. Check and replace it. If you wish to get some details; visit the site linked here. Pull up older posts.
Posted on Oct 12, 2017
6ya staff
SOURCE:
LG 32CS460 Lost freeview after cable unplugged
Check the cable connectors and the connectors on the wall and TV to make sure the cat didn't break any of them. (It seems odd that a cat would be able to pull a coax connector loose - maybe antenna cables in the UK aren't threaded as they are in the U. S. A.).
Oct 19, 2017 | LG 32cs460 32" Inch Widescreen 720p 60hz...
My Tristar TV signal booster has a red light illuminated, I think is says 'short' above it. Is the booster working? I have fault on my TV it maybe this. The booster has been working fine up till...
I too have a red "short" light on my Tristar booster. However- I've illiminated the Tristar as I unplugged it and connected my tv directly to the 13amp mains and b) connected the aerial directly to the aerial wall socket which is separately boosted from a distribution amplifier box in the loft. Picture was U/S so the "short" is probably in my cabling in the loft (I've been moving the aerial about lately).Hence I suggest initially to unplug the Tristar and check the fault is not back further up the line ie the cable and booster at top of house. Hope that all makes sense.ps before noticing the red "fault" light, my picture had gone to pot.
Jul 18, 2011 | Televison & Video
My Polaroid HDTV says no signal. What is going on.
  • Have you plugged in the arial?
  • Is it in the right socket?
  • Are you using an aerial cable extender/splitter?
  • Are you using a portable indoor aerial?
  • Does it have built in Freeview?
  • Have you plugged in an external Freeview box if necessary?
  • Have you scanned for channels through the Freeview box?
  • Are you in an area where the analogue signal has been turned off?
  • Have you subscribed to a cable or satellite provider?
  • Are you on the right TV source?
  1. check the back of the tv to see if the aerial is plugged in.
  2. check the back of the tv to see if the aerial is plugged in correctly.
  3. If you are using an aerial cable extender or splitter, make sure all parts are connected all the way up to the aerial.
  4. If you're using a portable indoor aerial you might not be able to get enough signal to produce a picture. Also the aerial might need to be switched on, plugged in or need batteries.
  5. If the TV has Freeview built-in then you will need to scan for channels before you will get a picture. refur to you're TV's manual.
  6. Make sure, if you have got an external Freeview box that it is plugged in and switched on at the wall. Also make sure that it is connected to the TV either by a scart lead or by HDMI cable.
  7. Typically there will be a button on the remote called menu. From the menu screen choose setup. Then choose auto scan. Follow any on-screen instructions. Always refur to the TV's manual to avoid confusion and frustration.
  8. If you are in an area where they have switched off the analogue signal you will need to buy a Freeview box or subscribe to a cable or satellite provider. Freeview is cheep and is a one off payment ( best for people who will only really watch channels 1-5)
  9. Ring up your providers tech support.
  10. To change what input you are viewing, there will normally be a button called source on the remote. If you have connected a Freeview or cable/satalite box to the tv with a scart lead then select scart. If you used a HDMI lead then select HDMI. (There may be more than one of theses sockets so check behind the TV first. They usually have names or numbers by the side) refur to you're TV manual for help.
That is every problem i can think of. If it still doesnt work, take it back to the shop.
Hope this helps.
Jan 11, 2011 | Polaroid Televison & Video
Hi I have two freeview boxes running from one aerial which split at a boooster box, one tv works fine, it the farthest away from the booster box, but the other has some channels freezing up and stuttering,...
The problem you describe is called "Digital Cliff Edge" and it's caused by signal loss. I wont go into the specifics of that at the moment as it's not going to help solve your problem. I you want more information about DCE, try an internet search.
As you are using the same aerial and booster/splitter for both TVs, you are correct in ruling these out as the cause of the problem. The fault is probably in the co-ax cables or connections but you might have a faulty freeview box. Please run through the following checks to establish the source of the fault.
1. Swap your Freeview Boxes - you shouldn't need to re-scan/tune as they are running off the same aerial..
If the Freeview box from the TV that is working correctly freezes and stutters on the other TV, the fault is probably in the cables or cable connections. Next, try the "faulty" Freeview box on the TV that is working correctly. If you get stuttering sound and freezing/pixellation you probably have a faulty Freeview box. DO NOT SWAP ANY CABLES FOR THIS TEST.
If the problem is the same after swapping the freeview boxes:
2. Swap any non-fixed cables, e.g the co-axial "fly-leads" and scart cables - one at a time. See if the fault "moves" with the swapped cables. "Fly leads" are the short co-ax cables that link the Freeview box to the TV or the TV to a wall mounted aerial socket. If the fault "moves" with the swapped cable, you have identified the source of the fault and should either repair or replace this cable.
Try these tests first and post back with the results. If you haven't identified the source of the fault, I will try to assist you further.
Regards,
BElectric
Nov 21, 2010 | Televison & Video
Lost our freeview. New TV in bedroom (Sharp LCD, LC-19SH7E-BK), which has freeview and was working fine. However, we set up a magic eye so we can have SKY (which we can now use through channel...
if you have connected your sky box as per instructions, putting the aerial coax to it and a fly lead(as in a male to female coax as used on a vcr to tv) from the output to the tv's aerial input, then disconnect the aerial from the sky box and put it back to the tv. The skybox will weaken and even loose the signal.
Feb 14, 2010 | Televison & Video
I can get channels 1 to 4 can't get channel 5 and no freeview
Hi, I had the same problem, try removing your aerial from the box - retuning and saving so it blanks out all previous channels and then reattaching the aerial and doing another retune, this worked for me. Good luck.....
Oct 06, 2009 | Televison & Video
Sony VHS model no: SLV-SE710G isn't recording now that we have a freeview box. It just keeps changing back to L1 whenever i try to record anything!! I only want to record channels 1,2,3,4 !! HELP!!
Its hard to work out without looking at your cables. I assume the problem started when the freeview box got set up. I would guess that the aerial cable is now in the set top box instead of the vcr as the vcr sounds like it is unable to record when there's no signal (a common feature) so there shouldn't be a fault with the vcr,
just unplug the aerial from the set top box & plug it back into the vcr. Ch 1 2 3 4 should be back on vcr but set top box wont have any Ch.
most set top boxes have an aerial output, so you'll need another aerial cable, plug this into the aerial input on the vcr & ch 1 2 3 4 will be there but these will be analog (if your area has stopped analog transmission thats the prob rite there)
If you plug the matching cables from the set top box into L1 on vcr you'll be able to record digital tv as L1 use a signal from another tuner eg set top box, dvd player whereas the vcr channels 1 2 3 4 use the vcr's built in analog tuner. so it shouldn't be a biggie another cable should fix it,
Hope this is helpful, ask if you need more info
Aug 20, 2009 | Sony Televison & Video
Find channels
You say you`ve plugged the outside aerial lead directly into the DVD recorder aerial input socket, you connected an aerial link lead from the aerial output socket on the DVD recorder and you`ve got a Scart lead from the TV output socket on the rear of the DVD recorder into the AV1 socket on the TV. I`m saying all this because in the past, I`ve had customers say this to me only to find when I call round that they`ve plugged the aerial into phono sockets instead of the earial input socket. The aerial lead will fit physically but not electrically. Have you got a good picture on your TV with the DVD recorder switched to standby?? If yes, Does it play a DVD perfectly through the TV?? If yes, then everything is connected up correctly, When you press the virgin menu button to your DVD, it should show setup/install?? When you do get to the free-view or channel setup/install menu, and you tell it to search for new channels, does it scan?? Does a bar or do the numbers rise and the % number rise as it finds new channels?? If they do and everything is connected and working as I described earlier but still no channels are found, Try unplugging from the mains and reboot your DVD recorder, then repeat the whole menu install procedure sequence again. Other than that, there`s nothing else you can do, Basically, you`ve got a faulty machine where it requires an engineers eye I`m afraid. Ian
Jul 29, 2009 | Wharfedale Televison & Video
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Setting up my freeview box- NO CHANNELS FOUND
Hi.
The cable & wireless system is not capable of picking up the digital freeview frequencies.
Idealy you need to put a new aerial on the roof,
If this is not possible try an indoor aerial that you to plug in to the mains electrical supply.
http://dysonmanuals.inc.io/
Chris..
Dec 11, 2007 | Televison & Video
LG 32LG30 32 in. LCD HDTV Logo
99 people viewed this question
Ekse
RONALD CARTER JR
