We have had model #795-77543600 for 2.5 years. Water is now not coming out of water dispenser or into ice maker. I changed the filter which did not solve the problem
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the
icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with
this miracle fix of using a hair dryer to melt the frozen water line
going to the dispenser output. This is highly unlikely for our model
since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't
enough water pressure to trigger the solenoid valve. $40, and still no
luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage
going to solenoid, so I wasted $30 for a new solenoid.....still no
water.
-4th thing was I ordered a new IR sensor and receiver (since the
reciever end is where the relay that sends the voltage to the solenoid
to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF
THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch
underneath the freezer unit and disconnected, and removed the freezer
unit to inspect it further.
When I removed the protective white cover that covers the mechanical
wheel, I had a few parts come flying out of it. Turns out that the
wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE
FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48
BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS
BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10
times it will fix your problems. All techs replace the IR set at the
same time too which will set you back another $58 bucks.
Good luck! ;)
Whirlpool Model ED5GTFXKQ02 Ice Maker Parts Breakdown
My husband pulled the frig out, did NOT disconnect anything and pushed it back. Guess what - we now have water and ice. Who knows why? Since the frig had not been moved since we bought it, we doubt that the water line was kinked suddenly. I have never been more disappointed with an appliance purchase. The Kenmore Elite model has been nothing but a headache considering how expensive it was.
