Go to task Manager > processes tab and find the StorageSync program and end process. Unplug the drive, shut down the PC, replug and start up the Pc and try again.
wrong file extension. if you made a image of the OS it should have been a .iso this is burnable and easy to open with winrar or a dvd burner program for image burning. The ISO file type is primarily associated with 'ISO-9660 CD Disc Image'. A literal dump of the data on the CD, byte-for-byte. The data is stored in the ISO-9660 format. IsoBuster can interpret these files directly.
The .wmf file type is primarily associated with 'Windows Metafile' by Microsoft Corporation. Microsoft graphic format. Xara X is a good program to edit this file type if you don't have Microsoft tools. There are several versions of a Metafile; each having a different header structure.
1.) Stop using the hard drive IMMEDIATELY! Do not drag or create any files on it. 2.) Download asoftech data recovery program: http://www.asoftech.com/adr/index.html 3.) Install and run the data recovery program against the hard disk
If the USB hard drive can be detected in 'my computer' as a drive letter(like E: drive) but you can't access/open it,you can recover data from USB hard drive with 3rd party data recovery program. Tenorshare data recovery is a professional data recovery program that can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage,system sabotage, virus attack etc.Download it and scan your USB hard drive for free to preview whether your files can be recovered.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm After you recover your data,you can format it to check out whether it can be fixed.
first, recover your files. You will need to use something like this data recovery program. http://www.asoftech.com/adr/
I've had to use it many times in the past but in this case you need to plug that drive into another system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
After you get back your files, you can then format the drive and reinstall your system.
