SOURCE: Rowenta iron manual needed
does not heat but indicator light is on.
Rowenta steam Iron Model DE-871
SOURCE: Iron spits out rusty water. The iron is a Rowenta
Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
SOURCE: I want to know how to clean my Rowenta Advancer
You can use ordinary white vinegar. Use about 1/4 cup or so mixed with 2 cups water. Fill iron with this solution and operate it at full steam setting(high as possible) Set a folded towel(may want to use an old one)iron on the towel and operate the steam device until all the liquid is gone. This may clear some of the scale build up. There are Generic brands available at the stores made especially for irons, but vinegar is the most enviro friendly and is cheap.
SOURCE: rowenta DZ9080 iron yellow light flashes but iron
it is possible that there is a loss in contact in the iron you will need a local repairs man to do that for you
SOURCE: I have a rowenta advancer DZ9080 iron that the
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
