I have tried many stainless steel pol;ishes to no avail also tried baking soda. HELP
Just a thought it may not work.
Since Muratic acid caused the trouble try it to remove the stain. Then after its removed use baking soda to kill the acid and within 3 toi 4 hours re apply baking soda and re clean. Maybe do the cleaning 3 times just to be safe.
I only say this because to remove oil you use an oil based solvent. Water use a water base solvent.
So maybe ...
Then again maybe not
If this works or doesn't Id like to know.
The last thing to use is a piece of aluminum tape to cover the area so its not brown.
If this helped you please rate me accordingly and good luck.
