This is a response I received from Champion Juicer- I am amazed at how fast they responded. His solution is below-
Hello Cathy
To remove the cutter from the Champion Juicer motor shaft, take two small
screwdrivers and place them between the back side of the cutter and the
stainless steel portion of the hub. Apply pressure on the screwdrivers and
the cutter should begin to slide forward. When driving the screwdrivers in,
make sure they are spaced far enough apart so they don't damage the motor
shaft which is located in the center of the cutter. If the cutter does not
come off, leave the screwdrivers in place and insert something under the
rear of the Champion Juicer (like a book) to elevate the rear of the
machine, thus allowing the cutter to tilt forward. Apply penetrating oil
between the screwdrivers. Because the cutter is now angles forward the oil
will run inside the cutter. If this is done for several days the cutter will
come off by applying more pressure to the screwdrivers. By merely pulling on
the screwdrivers you will have to use a plastic hammer and slowly tap on
each of the screwdrivers until the cutter breaks free. Tap one screwdriver,
and when it is snug, tap on the other screwdriver until the cutter breaks
free. When this is done there will always be one screwdriver coming loose
and falling out of the slot. Do not rush the removal process; give the oil a
chance to work. It is possible the hub and cutter will be damaged during the
removal process. Contact us for current replacement prices. Once the cutter
has been removed you should polish the motor shaft to remove any film or
burrs which may have developed. If you contact us with your address we will
mail you a piece of fine emory cloth to polish the motor shaft at no
charge. You should always apply a slight film of olive oil on the motor
shaft to prevent sticking of the cutter. Do not use other oils, as they tend
to break down from the heat during operation of the juicer. If you wish to
speak to a repair person, please call our company weekdays @ 209-369-2154
between 8:30 a.m. and 4:30 p.m. Pacific Standard Time. We would be happy to
offer any assistance you may need.
Thank you
Carl
Hi I had different problem yesterday and emailed Champion Juicer about the problem, his suggestion worked. Here's his email below. [email protected]
what's good about your solution? you never posted the email with the solution; Hello
My cutter is stuck on the shaft. I cannot take it apart. Help please. I'v e tried pulling hard and running very hot water on it, to no avail.
Andree Deveault
Montreal
[email protected]
Exact same issue here. I've been banging away at it with a screwdriver & oil and have only been able to move it about a quarter inch off the shaft. Help.
I have been using my juicer for approximately a year. Now I am unable to remove the cutter from the metal shaft. I have pulled it with all my strength; however, it does not budge. What do we do?
I can't get the cutter on all the way and I can hardly get it off again. My machine is 20-25 years old. The motor is strong.
Borgny Parker
borgnyehp@gmail .com
