Ricoh FAX2210L Plain Paper Laser Logo
Posted on Mar 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sleep Mood I need to set our Ricoh Fax 2210L on sleep mood between the hours of 5:00 p.m - 8:30 a.m.
  • Anonymous May 11, 2010
    It should go to sleep after 10-15 minutes of non-use anyway....it wakes up automatically to receive faxes or print jobs....not sure what you're trying to accomplish
Anonymous
Level 3:
Genius:
  • Master 2,120 Answers
  • Posted on Mar 18, 2009
Anonymous
Master
Level 3:
Genius:
Answers
2120
Questions
0
Helped
670157
Points
5011
Does not have that feature.
tip
How Can a Sleep Mask Help Me?
Sleep isn't something that we can do without. Not everyone seems to need the same amout of hours sleep but a block of sleep is necessary every night in order to function well during the day.
Insomnia is a problem on some level for millions of people world wide and people use all sorts of solutions; from drugs to herbal remedies, meditation to sleep masks.
In order to feel rested, we need to have Deep Sleep. Sleep occurs in cycles. Deep sleep or REM is the fifth of the sleep cycles and is the most important one.
Deep sleep allows our minds to really sift through memories, stress and feelings. The body at this time might appear very active as extremitites can be twitchy and blood pressure and heart rate can increase but actually the body is going through a period of great rest.
So if deep sleep is so good for us - how do we get more of it?
Both quantity and quality matter when it comes to sleep. You need to sleep enough hours so that you have time for deep sleep cycles.
But when it comes to quality of sleep, there are things you can do to help yourself.
- Make sure you dont' have any lights left on. Even small computer lights can disturb sleep.
- Have a regular bedtime routine that you try and follow every day so that your body knows the signals.
- Use sleep masks to aid a deeper sleep. They will block out any tiny light and allow you to really fall into a deep sleep.
- Sleep masks are also really helpful for people who need to sleep with some light on.
Getting a good nights' sleep can help with mood, weight, memory and even our immunity to getting sick.
It's such a simple need and yet so many people don't listen to their bodies.
So I suggest that you invest in a sleep mask, follow the steps above and see if it helps you to feel better.
on Jan 06, 2014 • Health & Beauty
Won't resume after sleep mood
Take the battery out of the computer.... Unplugg the charger and just the turn on key for 2 mins...
After that connect that charger and the battery and tyr to turn on the computer..
The issue should be fixed
18helpful
My Toshiba's laptop's sleep and charge USB port
It's possible to fix. First go to device manager and you should see something like "USB Root Hub". Double click to open it, go over to power management, and "Uncheck" "Allow this computer to turn off this device to save power". Do this for all that say USB Root Hub. Next go to "Power Options" then "Edit Plan Settings" (accessible through "choose when to put the computer to sleep") and select "Change Advanced Power Settings". Next, make sure you do this in all of your power settings, but scroll down to an icon called USB settings. Expand the selection, then expand the "USB selective suspend setting". Choose, both on battery and plugged in if you want, to Disable the selective suspend. Finish and apply. Also, to confirm, you know that the USB device (IPod) but be plugged into the eSATA port, correct? It doubles as a USB port and is the only one capable of charging.
Montor will not come out of sleep mood
Hi...there,
It's seems you got a busted backlight inverter. Need to replaced a new one or repaired it.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
