GE WSXH208A Front Load Washer Logo
Posted on Mar 13, 2009
Keep needing to reset washer dryer
I have a Service 8kg washer dryer after I dry clothes then I need to reset it by opening it up and pushing the reset botton is there anyway I can prevent the reset botton from tripping?
Anonymous
Level 1:
  • Contributor 478 Answers
  • Posted on Mar 13, 2009
Anonymous
Contributor
Level 1:
Answers
478
Questions
Helped
164365
Points
61
Check the vent lines to be sure the path is clear
AEG model T76280AC weight problem
Yes, 8 kg
AEG T76280AC Tumble Dryer, 8kg Load, B Energy Rating, WhiteWith a maximum drying load of 8kg, it's ideal for busy family households. This ProTex dryer features an XXL Soft Drum with 3 lifters to give you great results every time whilst treating your delicate clothes with the care they deserve.
AEG T76280AC Tumble Dryer, 8kg Load, B Energy Rating ...Here are all your spare parts, there is nothing listed as a weight sensor. Phone Ransom Spares for advice. My guess is that it is the moisture sensor. There is a button on the page that shows the parts in schematic form.
https://www.ransomspares.co.uk/parts/brands/aeg/tumble-dryers/t76280ac%20(91609709402)/
Jan 30, 2022 • AEG Dryers
Where is the filter on my aeg protex washer dryer
Tumble dryer Lavatherm T75280, 8kg
23988722-wycorcio5u0xxoh2plbhrodj-3-0.jpg 2. Open the filter
23988722-wycorcio5u0xxoh2plbhrodj-3-14.jpg 23988722-wycorcio5u0xxoh2plbhrodj-3-20.jpg Dado
My dryer is Tcm570 it started leaking water on the floor while clothes are drying, then not drying after circulation. But if I try to put it on now it turns all the power in the house off. What's
There are a lot of parts to this problem: First don't plug it in again or try to restart it...yet, Make sure before you reset the circuit breaker that you unplug the dryer. So now your home should be fine! The dryer is another story... I have answered this problem for others and with other dryers... Please focus on your washer, there should be very little water that remains in your clothes after the wash cycle and the clothes should Definitely not be dripping. Check to see that your spin cycle is working and if necessary run it through the spin cycle again. You may be overloading the washer. Back to the dryer...NO water should EVER drip from a dryer! If you do not wish to call a service person I would wait about 1 1/2 weeks for the dryer to dry itself and give the dryer another try after that and set it for Air dry only (no heat) if you don't have a problem at that point then stop the dryer and set it for a low heat cycle and try again. I think at that point you should be OK? If you do have problems.. you will have to call in a service person. But please remember clothes should be quite dry coming from the washer before going into the dryer.
Jan 12, 2013 • Dryers
Dryer only shuts off when door is open
test the push button for open and faulty .However see this causes too.
Clogged Vent
If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle:
The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Heating Element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace the heating element. You can check for an ohm reading but will need to refer to the service manual for proper reading. This sometimes on the tech sheet located somewhere on the dryer. Usually between 9-13 ohms.
Cycling thermostat
Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork . This thermostat usually has four wires going to it. Check the 2 terminals that are opposite each other and are the closer together of the 2. These 2 terminals should have continuity. If not replace the thermostat.
Whirpool dryer model wed9400swo the dryer door pops open
This usually occurs when the load is too large, causing the cloths to push the door open. If this is not the case, you should replace the door latch mechanism, which is what keeps the door closed.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
3helpful
2answers
Washer-dryer # wm3677HW will not dry,heats up, run, on and on
You're a moron. This unit washes and dries. That's the whole point of it. Perhaps you should do some research before answering the question. the most likely cause is the water lever sensor.
2answers
Splendide 2100 no longer dries clothes
We had the same problem with our splendide 2100 top loader. If you remove the top cover, you will find 2 circular like black discs (the size of a dime) on the right hand side about 6 inches from the front. You need to push those down (with a very small blunt object) to reset them. Please make sure that you unplug your washer/dryer before you attempt this. Good luck.
2answers
Not drying
Is it still under warranty? I've read that these machines are better left at the retailer...
Clothes dryer
washer dryer and dryer ony machines differ in a huge way. the big diff. is the drums on each are completly different sizes. the conventional dryer has the bigger, giving better air flow and tumble to clothes. the w/d has a smaller drum thus less air flow and less tumble between clothes. the best way to see this effect is remove half the clothes after a wash and then select a drying cycle. u will see that by giving the clothes more room to tumble free of each other rather than tumbling in a large ball will dry them. washer dryers are really only a marketing tool.
(ex main brand engineer)
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
