Starter, after turning the ignition switch, spins, but do not snap to motor.Have no idea where,or if is some "starter motor relay"...
Usually if the starter spins but does not engage the flywheel, the problem is the flywheel or the bendix drive in the starter. The starter gear is supposed to extend to meet the flywheel when the starter spins.
Testimonial: "Thanks. But I had already starter motor out of car,everything is working. I checked wires and the same.. I changed battery (about low voltage),fuses are ok too ,still the same. So problem must be with some relay.. And diagnostic snow my nothing !!! "
Then check the key switch may be defective or the fuse might have blow out...............
SOURCE: H2 Hummer
Today 11-12-08 my 2003 H2 Hummer would not start. Checked battery it ischarged. Cables tight. Tried to start with portable booster pak. No go. Tridto jump start with my wife's Suburban. Still no go.
When I turn the switch I hear a single click and that is it. No engine turning over. While trying to start with key the headlights go out. Out of ideas, Will take to Chevy garage in am. Will post solution.
SOURCE: Starter relays does not operate. Cannot turn starter
Clutch pedal rely switch, like brake light switches can go bad.
Have a great weekend.
SOURCE: 20 amp ignition fuse keeps blowing
I'm curious, does this vehicle have an alarm/remote starter? If so I expect the installer didn't wire it correctly ... it was an all too frequent issue, with inexperienced installers we had .... I would first suspect any add-on device first (if any) ... In answer to your question ... I know it does have a relay (Starter solenoid is a relay and built onto the starter) As far as it being a relay or the IGN switch ... I'm skeptical.
SOURCE: 2000 ford focus no power to starter moter i can
The mechanic should check on the wires and fuse going to the starter motor and the spare parts . since when you test the starter motor and seems no problem to it ,it means that the problem is in the other spare parts connected to the starter motor .check the alternator if it is good and functioning well. The solenoid you also have to check it to be sure because it is very much connected to the starter motor .those spare parts that are worn out or destroyed , you should replace them .
