I am trying to change the seal and take some rubbish out of the drum. The back and top and panel come of easy, but how to take the front of the machine? There are no screws, no clips. I can see it isn't one piece, but it is stuck together by welds or something. I can't find any videos/instructions on this model. Thank you.
SOURCE: indesit washing machine model WM 110 6kg
There are shops in Dubai which could help you. And lots of Philipinos in Dubai - they could surely help.(!) Wil try to get you an email of a shop.
SOURCE: indesit washing machine w1235
could be the bearings or heater/heater may of lifted or spider sometimes a coin can get trapped
SOURCE: indesit wash machine drum bearing
Some models like the WE12 have sealed drums where the bearings can't be changed. You have to buy a complete unit for about £120.
SOURCE: Trouble with Indesit WI 102 washing machine
I had trhe same problem and was going deaf!!! I know this is probably too late for your machine but it may be usefull to someone else with this model.
Originally thought the bearings had gone but had great trouble trying to source some through UK websites so decided to strip the machine. Did this by touch (no manual!) and eventually found that the bolts holding the bottom weight to the drum had all come loose (all 3!). Trying to access them to tighten was the biggest problem as the front of the machine is welded on.
Managed the above by removing the rubber door seal from the door only and tightening two of the bolts from inside the door. The third I managed to access from beneath the machine. All were tightened using 10mm socket on a bar with extension (curtain pole!) slid over the end.
During this process I had the machine on its side, removed the securing brackets, top weight + springs and wedged the drum from beneath and the side as much towards the rear of the machine as possible to aid access.
Good Luck!
SOURCE: Bearings getting noisy
no need to remove the drum
u just unscrew the screws and spyder wil come and u can change the baring
