Try this link:
Basically it's resetting windows password using a bootable linux usb memory stick. Use Ubuntu Linux To Reset Your Windows Password
SOURCE: Hp Compaq nx9020 bios password screen
The easy way is to open up the laptop and remove the smal batery from inside for about 15 minute and put it back, the hard way is to dowload KILLCMOS from internet put it on a flopy disk and insert the flopy disk if you have one in your laptop and falow the prompter
SOURCE: crashing a compaq nx7010 o n purpose
You can directly do this with setup boot diskette (came with your laptop).
There you'll find the option to format and do a clean installation of windows.
For this, you need to configure CD-ROM as your first boot device and follow on-screen instructions after booting.(i am assuming that you've done the formatting and clean setup before)
Thanks.
SOURCE: Need password unlock code for HP Pavilion dv5
You can start it in safe mode pressing the F8 key...it change between brands but must out there use f8... when you start in "safe mode" in the log in screen you will find your user name and the administrator one...normally the administrator don't have password, so you can log into it and there you have the permission to delete other users passwords...
If you don't found that option, there is an other option but you need to download it and burn it in a cd... Is called ERD Commander here is the link for it: http://rapidshare.com/files/113560492/ERD.Commander.2008.CrOwN.rar... the password for decompress it is:( munda
) when you have burned it, insert it in you cd drive> go to your computer bios>select boot priority>change it for boot from cd first...once you have done that press f10 and select the option yes to save your settings and restart your pc....then your computer will start with a wizard looking like windows xp...complete all the things that it request...when finally boots up>go to start menua and select system tools>locksmith and delete all the passwords that you want...that's it! restart without the cd in the drive and log in! "Hope it works for you"
SOURCE: Audio drivers for HP compaq nx7010 with Windows 7
This WEB site can supply the Windows 7 drivers, please click on this link :-
http://www.user-guides.co.uk/cddownload/HP/HPCompaq/HP-Compaq-nx7010-Windows-7-Driver-Recovery-CD-Restore-Disk-313489.html
