The Fridge and Frezzer Combo is not cold enough, seems to be at Room Temp
SOURCE: fridge doesn't get cold enough
If the evaporator fan is not running. The fan itself could be faulty or the door operated light/fan switch could be faulty. If the evaporator fan is running. The fridge is not defrosting and ice has built up on the evaporator and the air is not circulating properly into the fridge compartment. The fan circulates cold air into the fridge and back through the fridge control which is normally just an adjustable flap which allows more or less cold into the fridge depending on the setting. If the fridge is not defrosting, the defrost timer could be faulty or heater element could be blown.
SOURCE: Amana Fridge with bottom Freezer
either the switch or the temp sensor it broken. on the sears site you can get the part number
SOURCE: My freezer dosen't work but
Normally it is the temperature of the refrigerator that shows the first sign of a problem because the refrigerator is cooled by air from the freezer. Check the back wall of the freezer for signs of frost. If there is frost on the back wall you have a defrost system problem.
SOURCE: Frigidaire Electrolux Not freezing but fridge seems cold
You may be having a freon issue. Read some more info about this here. I type the longer version on my site. There are also factory service manuals to that may be helpful.
Appliance Outlet
Thanks,
Bill
