Washer works except on spin cycle. i hear motor running but no agitation.
With the washer set for spin and turned on...raise and lower the lid.
If it spins replace the timer.
If it does not spin...replace the direct drive coupling on the motor.
http://www.youtube.com/watch?v=WLPGs2UMU...
This video will show what you need.
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
I took the washer apart found the coupling was in pieces and replaced it. Now I dont remember how to put the washer back together.
