Handle is part of the control panel cover in the center area which is connected to two plastic supports that cracked and caused the handle to break-off. Now I have no easy way to open the dishwasher and where do I go to get some replacement part to replace the handle which is a molded part of the cover at the top of the dishwasher?
You have not put the full Enr, but from the bit you have added I assume you are in the states. I think you should be able to get parts from
http://www.searspartsdirect.com
Usually if the control panel breaks on this model, it is because you have the child lock activated on the door latch inadvertently and therefore have to force the door to get it open. This in turn puts stress on the panel which will eventually break. When you get the new panel ensure that you remove the child lock from the door latch. If you take off the front fascia panel and look at the door latch (centre top) you will see a yellow lever attached to it with a spring, just pop this off and you will immediately find that the door is much easier to open.
All the best.
