Question about Toro Lawn Mower With Toro Power Tools
Toro 149cc Lawn Mower Won't Start - Toro Lawn Mower With Toro Power Tools
    New Friend:
  • 5 Answers
Fuel or spark? Check spark by spraying carb or break cleaner into air intake(remove air filter)! If it tries to start you have spark. However you have fuel flow issue!
Remove the carburetor by removing two 10mm nuts on air cleaner and two 10mm nuts on top of exhaust. Disconnect armature from top of exhaust. Slide carburetor off then turn throttle connection on carburetor 90 degrees to remove throttle armature(you should be able to rotate carb to remove spring without bending. Put gasket aside. Remove the bowl at the bottom by removing center 10mm bolt. With a flathead screwdriver remove main jet by turning counterclockwise. Should be two pieces(skinny end goes first) ;-) . Use your can of break or carb cleaner to blow out the gunk(need pressure)! Look through the holes with a good light source on opposite side to make sure obstruction has been cleared. Reassemble in reverse order and mow!
Posted on Apr 25, 2018
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 30 Answers
Bad carburetor your old fuel jammed up the jet so it won't get fuel and if it does it will start and shut off So replace the carb or try to clean the jet and run non oxy fuel only
Posted on Jul 03, 2016
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 305 Answers
Most gas mower carburetors have a tiny hole for the fuel to rise into the vacuum venturi throat of the intake. The hole in this riser tube which goes down the center of your float chamber to the area where the fuel sits in the bowl is only as big as dental floss. Take the tine of a wire brush to clear it of crystallized or varnished gasoline and oxidized pot metal tube crust. When they make stainless carburetors, it will eliminate half of the heart attacks caused by this problem. Additives and condensation that settle out in old gas also can lead to clogging.
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Toro Lawn Mower Won't Start
this is a very common problem with these toro mowers. the needle valve in the bowl of the carb. is plugged up with dirt or varnish from the fuel. just under the primer bulb there is the carb bowl. it has a nut under it that holds it on remove the bowl and make sure fuel flows constantly while the bowl is off. push up on the float to stop the gas flow. this could be messy and dangerous. careful with the gas. its flammable. best solution is to remove the carb and soak it overnight in a parts cleaner like gunk. caution small parts inside. this happins every year on mine no matter what i do. seems like the orifice is so small it clogs easily. good luck
Posted on Nov 15, 2008
Anonymous
  • 86 Answers
SOURCE: I have a 2006 Toro 6.75 hp GTS lawn mower. I am
Your carburetor needs cleaned,you had gas in it that you drained out and replaced with new ? What engine do you have tecumseh,briggs,? Anyway remove carburetor and take apart get acan of carburetor cleaner and spray though jets in carburetor and blow out jets be carefull not to blow out needle seat !
Posted on May 16, 2009
Anonymous
  • 6 Answers
SOURCE: I have a GTS 6.5HP Toro lawn mower it start good
Does the fuel line have a filter? It sounds like the float in the carburetor is running out of gas. Sludge builds up and the deposits on the needle seat will not let the flow of fuel to be metered correctly.Drop the bowl down off the carb and check for junk in the bowl. Check to se if the float is set at the right setting. Little pieces or rust in the bowl will be sucked up into a jet and plug it up and stop it from running. Do not leave gas in your mower over extended periods of time, this is the cause of sludge and rust build up in gas drawing moisture.
Posted on Jun 13, 2009
Testimonial: "Icleaned the bowl it works good now"
Anonymous
  • 17 Answers
SOURCE: My Toro lawn mower won't stay running. It will
You need to check a few things. The spark first, you need to check if it is running correctly, does it have spark, by doing this: take out the spark, put it against a metal surface and pull the pull start if it spark, your good if not you need a new spark plug. Clean out your airfiilter it migth help too. Buy some carb and choke cleaner squirt it up theough the airfilter hole, and start the engine, this will clen the carb. yOU MIGHT NEED TO TAKE OUT THE CARB AND CLENA I OUT THROUGHOULY!!! Try that and it whould work after all these steps!
Posted on Aug 11, 2009
Key won't start my mower
starer is dirty take apart and clean dirt out of it reassemble star it
Sep 08, 2014 | Toro Recycler 22" 149cc Personal Pace Lawn...
Toro z master won't start
bypass the safety switches one at a time to test them
Sep 19, 2012 | Toro 52" 27hp Z Master Zero Turn Lawn...
Toro self propelled mower. blade won't stay tight
Use a block of wood to hold blade stationary while tightening bolt. Ensure threads are cleaned with a wire brush before tightening. Is there a spacer or washer missing?
Jun 26, 2012 | Toro Power Lawn Mower
Toro 6.5 tecumseh won't start
replace your spark plug. it takes a Champion J19LM. If you left fuel in your tank over the winter then drain your tank and your float bowl. Add clean fresh fuel and it should go if not you need to clean your carb
May 17, 2012 | Toro Power Lawn Mower
TORO ZERO TURN MOWER WON'T TURN OR MOVE ONE WAY
This page says there's one solution. What is it? Where is ti?
Apr 13, 2012 | Toro 60'' Zero Turn Lawn Mower Enclosed...
Toro mower won't start
bad safety switch or bad coil
Apr 07, 2012 | Toro Power Lawn Mower
I have a Toro 20" self propelled, electric start
I am strictly Briggs&Stratton. They are hard to start when the fuel tank is half empty. Clean the plug and air filter.
Jun 15, 2011 | Toro Power Lawn Mower
Looking for a manual for a Toro 22 inch recyler. Lawn mower hs 6.5hsp tecumseh engine. Won't start. Do not see spark .
You can search for your manual as well as other helpful information at the following site:
https://homeownersolutions.toro.com/portal/server.pt/community/product_center/225#productDetailsPage
It would be helpful to have your Model Number and the Year your machine was made.
May 23, 2011 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
4,109 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
roeb
Marvin
Marvin
Are you a Toro Garden Expert? Answer questions, earn points and help others
