If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it
with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present
charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
I already thought of that one myself, but what clarification do you need? If it is indeed the new HP battery, then there must be a way of proving or confirming it.
As you can see in the write-up, I installed the new battery, and it went up from 25% to 30% max in the computer. (First step of re-calibration) I removed the charger lead and it discharged slowly until the computer closed down. (second step) That is as far in the re-calibration process I got. Now the battery does not charge as explained above.
I am an Engineer and a Project Manager.
When I normally look at a problem, I define ways to apply specific tests to prove the location of the fault or problem. Following this analysis, I devise ways to correct that fault. That is what I was hoping for from this forum.
In the event, I did the following: -
1) Check the battery in another computer for charging. It did!
2) I charged it to 10% in order to overcome any discrepancies in the low voltage charging inhibition between computers and attempted a re-charge again on my own computer. Result - about 1-2% increase in charge in the battery indicated before cutout of charge again. By this method of removal and replacement of the battery it now stands at 26% charged and rising slowly as re-booting etc takes place.
3) I then referred to the HP website, and learned that I may have a problem with corrupt software in the charging circuit somewhere, and I ought to re-install Vista on a clean disk to ascertain whether or not that is the problem. if it is, then at that stage it will be solved.
Any comments please?
check your battery were you bought...
yeah sumtimes theres a defective ....ok just try to calibrate your battery
i hope can help you.,,
i think the battery you replace is maybe deffective...
