Dishwasher won't run only starts to fill. Timer counts down but nothing happens. Electrical smell from front door after a few minutes.
Do not use this appliance until you have check if it is one of the bosch dishwashers subject to a recall repair. Use the link below to check
http://www.repairaction.co.uk/bosch
SOURCE: Electronic controls don't count down properly
Your problem is the electronic control board and unfortant that you cant repair or even get parts for it . Only if you get the whole control board will you fix your problem assy unless you find a good appliance man that repairs electronic control boards
SOURCE: shu5312uc bosch dishwasher
Since water doesn't drain out,it could be a clog in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
you have to replaced the main control resoldering wont fix it because the relay itself has gone bad replacing the board will solve the problem
SOURCE: Bosch dishwasher shu43c - no water is getting in.
The problem is in my free guide. It is here. Odds are the drain line is plugged and it isn't letting in water because the old water isn't being pumped out.
SOURCE: Bosch dishwasher timer sticking
I have been told to replace the timer which I am looking to do the same to my machine!
