Question edited for clarity. Please always include full make and model.
Question moved to RVs.
Sounds like you need a new garage!
Either the new battery is flat or the starter solenoid is faulty or they hit the inertia cut off. Did they reset the security system after disconnecting the battery?
you are not alone. There is an inertia switch behind the battery.
The most likely problem is a failed safety switch in the transmission. It will only allow the engine to turn over when in "neutral", or "Park". Next time it happens try moving the transmission selector through the full range of travel a couple of times. If this cures the problem, you may need new switch.
Things to check: Drive/Free wheeling switch, brake release lever (this activates an internal micro-switch that enable power to the drive system, battery box connectors (condition of contacts - corroded, missing, loose. etc.); main control cable (corrosion. lose or missing pins, etc). If all these are OK, could be controller or drive control potentiometers (speed, forward, backward) on the handle-bar (tiller). Good luck!
Your camera is still under the one year Nikon warranty. Call Nikon's repair depot at 1-800-NIKON-US (1-800-645-6687) 9AM-8PM EST, Monday to Friday. They will verify your warranty and assist you in returning it for repair.
