I have a Ladies Armitron All Sport watch Model #45/6967.I can't change the time.On my watch I have as follows: Mode=A lower left button,Set= B upper left button,Adj.=C upper right button,EL=D lower right button.( I don't know what EL stands for ,but when I press it my watch lights up in the dark.)I did not get any instructions when I purchased the watch. Can anyone help me?
hi Robert.
i can not find a manual for this watch,but if you go to this link it should show you step by step on how to set it up.
its not showing your model number so not sure how good it will be to you.
if another window opens on the page just close the popup window down.
or try this. How do you set an armitron pro sport watch?
Press the "Mode" button repeatedly until the time display appears on the watch. Hold the "Mode" button until you see the alarm display appear, then release the button. Hold the "Mode" button a second time to enter the time-setting mode.
Hi there I see that you are in need of assistance setting time on your Armitron Wrist watch.
I would be more than glad to give you details on how to, Please see steps below.
Your Armitron Watch will have Four Button on the side of the watches rim.
Button on the upper Left is MODE.
Button on the lower Left is LIGHT.
Button on the upper right is DATE.
Button on the lower right is Alarm.
See Steps below: *Setting the time*
Press and Hold down the Mode Button til the Hours flash
Then push Alarm Button to set the Hours
Press and Hold down the Date Button till the Minutes flash, then push D/Alarm Button to set the minutes
After setting the minutes on your watch, Press date till you get the month flashing push Alarm to set the month
Press the Date again till the Date flashes, then push Alarm to set date
Press the Date again till the Date on your watch flashes, then push Alarm to set the date
After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
I will be glad to help you with your concern regarding your Armitron
Wristwatch, what exactly would you be experiencing? cause I only put
info on how to set time and date on the Watch.
Please see below steps:
Button
Button on the upper
Left is MODE.
Button on the lower
Left is LIGHT.
Button on the upper
right is DATE.
Button on the lower
right is Alarm.
See
til the Hours flash
Press and Hold down
Minutes
flash, then push Alarm Button to
set the minutes
watch, Press Date
Press the Date
Alarm to set date
the date
I
On the face of the watch, there are four buttons arranged around the circle of the watch face in four positions. Starting with the upper left hand button (labelled SET), and working clockwise around the face of the watch (to ADJ., EL, and MODE), I'll label the buttons "A", "B", "C", and "D".
In other words... Button "A" is the button labelled "SET" in the upper left hand corner of the watch. Button "B" is the button labelled "ADJ." in the upper right hand corner of the watch. Button "C" is the button labelled EL in the lower right hand corner of the watch. Button "D" is the button labelled "MODE" in the lower left hand corner of the watch. Setting the Time. 1. Press and hold D as if you were setting the alarm. As above, the stopwatch will momentarily appear and then after 2 seconds the alarm time will appear with the hour flashing. 2. Press and release D and the seconds on the time of day will begin to flash. 3. Press and release B to reset the seconds to zero provided they are below 30. If they are above 30, the seconds will reset and the minutes of the time of day will advance by one. 4. Press and release A to change from flashing seconds to flashing minutes/flashing hours/flashing day of the month/flashing month of the year/flashing day of the week. In each flashing mode, pressing and releasing B advances the value by one unit. 5. Press and release D to exit time setting mode.
Thank you for contacting FixYa.
Light = A - lower left button Mode = B - Upper left button Date = C - Upper right button Alarm = D - lower right button
Set time time / date
Press and hold B (Mode) untill alarm hours flash Press D (Alarm) to advance these Press B (Mode) again, seconds will flash, press D (Alarm) to advance these Press C (Date), minutes flash, press D to advance these Press C again, hours flash, press D to advance these
Best regards. Jewel
mcdevito75 here, One of the buttons should show MODE on the case of the watch, press that MODE button and see flashing, now press the set button to set time, each function you set, Time, day, date you have to pess the MODE button again to move onmto the mext function. Once all the functions are set press mode again and see a steady display.
Armitron alarm/chrono
1.To set the time hold the mode button until the alarm flashes, then hit it one more time and the time will flash to be changed. Once the alram or time is flashing use the ST/STP button to navigate between hour, minute, month, day and day of the week, the ADJ button changes the numbers.
2.While holding down the ADJ button use the ST/STP button to turn off the hourly CHIME and the ALARM chime.
Hope this helps!! K~~
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Armitron says if the model is not listed on their site call them 718-784-0700. I did and they promptly e-mailed me PDF.file instructions for my M516 watch. - David
same as elliecat926 however the model is 44/1001
