I have found my drive but cannot find any of the attaching cables.
SOURCE: does simple tech 250 drive need an external power source?
Yes, you need a power supply. I have several USB peripherals that, in a similar way, APPEAR to be on when you plug them into USB. But that interface cannot supply enough power to actually run the machine. The maximum is 0.5 A * 5 V = 2.5 W. The wee portable drives can run on that power, but a normal desktop drive, such as is inside a full-size desktop external enclosure, use ~ 8 W.
So you need a DC power supply! I bet SimpleTech can tell you what the correct current, voltage, and polarity is. Good luck.
SOURCE: how do you use SimpleTech SimpleDrive S500U 500 GB Turbo USB 2.
http://www.simpletech.com/content/support-user-guides
That link is a page with all the user guides for simple drives. This should supply you with instructions. If you need any further help, let me know.
SOURCE: Simple Tech USB Drive will not work
I have a Simple Tech USB Drive that will not work. When you plug it in the lights blink, but you cannot access the drive. How do I fix the drive and get my information out of the drive?
SOURCE: my simple drive (simple tech) portable hard drive
I would be very concerned that the drive may be failing, and make copies of anything important.
Is the external drive full? Go to My Computer and right click on your external drive and click on properties and it will tell how much is free and used. 90% is very full. Check all your hard drives while you are at it.
You should go to the website of your hard drive maker and download a diagnostic utility to check the health of your hard drive. It will be on the website under support. This must be run from bootable floppy, bootable usb, or bootable cd.
