Usually four items are changed. The two bearings , the seal, and the shaft. When you did your first repair the shaft should have been replaced. The reason the noise continues is that the shaft wobble even as minor as it may be ends up beating the new bearings to where they start making noise again. The new kits are better designed and can be found for under 100.00 dollars. Shop around for the best price. Good Luck Friend.
SOURCE: grinding noise
The Neptune bearings are an interesting breed... Maytag wants you to replace the whole outer tub which includes the bearings installed for $180 or so. You can replace the bearings yourself. See www.tonytool.com to see how it is done. The tool costs $379 or so... but it is designed for the service tech. not the d.i.y.er. But watching the video can give you an idea of how to do it yourself. The bearings were available on www.neptunewaxmotor.com for about $35.00. You will also need the Maytag seal kit 12002022 to complete the job whether you decide to replace bearings or the outer tub.
SOURCE: Maytag Neptune bearing noise
John,
What are the first two numbers of your serial number i.e.10 through 17. I’m an owner like you not a repair person….. but I have a very good feel for machine issues and the repair of the machine. See my ratings under this nick name FAV6800AWDIY and my old original nick name dh1200s.
The biggest problem with FIXYA is they don’t ask the user for Model or S/N of the machine. I can’t believe how many professional repair folks jump in with comments and they have no clue as to what machine is being discussed.
You may end up going with a replacement if it’s the Outer Tub Bearings. I would remove the tub and try to replace before I would junk a $1000 but that’s me you would need to decide. This a weak repair area for me I have not replaced the outer tub bearings on any of the three FAV66800A’s I own but I feel confident I could do it. I buy these cheap and repair for resale.
Have you had the Clutch Pulley removed/replaced in the past for dC or uC error code failure in Spin Cycle?
I would drop the Clutch Pulley out and clean up/re-lube the One-Way Roller Clutches and check for signs of a tub seal leak. Then with the Clutch Pulley out spin up the Wash Basket CCW as fast as you can by hand and listen for bearing noise of the Outer Tub Bearings. Let’s make sure the One-Way Roller clutch bearing is not the bearing noise source. See this post for removing the clutch and doing maintenance and replacement. Clutch Fix Post
I have to post rest of this comment as a comment. This forum is not geared up for DIY responses.
SOURCE: maytag neptune washer noisy when in spin cycle.
You have a bad rear bearing in the outer tub. The entire outer tub would need to be replaced to resolve this issue.
Check your owner's manual to see what kind of warranty you have on this part. I'm keeping my fingers crossed for you as this is an expensive repair!
Good luck!!
SOURCE: Maytag Neptune Model #mah5500BWW We know it a
There are 2 bearings and a seal. To remove inner tub you'll need to use a hammer/mallet or special tools, and you'll need to basically strip the washer to get to the inner tub. Maytag (Whirlpool) does not sell bearings separately, look them up on ebay, use "maytag neptune bearings" as a key phrase. IIRC, the special tool was also available on ebay for lease. Instructions on how to replace bearings are available there also. If no luck on ebay, try googlee for the same key phrase.
Good luck,
Vlad
First Choice Appliance
