The problem is i can't use the mouse at all. I can not even connect it to my computer. At this moment I am using a dell keyboard and a dell mouse. They are both wireless and have a receiver that makes it connect to the keyboard and the mouse. The problem is I tried everything I could think of and it still doesn't connect. I've tried new batteries, remove the dell wireless mouse and keyboard, and also even reinstall the software over and over again. What should I do?
SOURCE: Microsoft Natural Wireless Laser Mouse 6000 doesn't work
Hi
If you take the batteries out there is a screw in there. unscrew and open (not easy) with flat knife in the edges wiggling.
attach and touch all the inside wires. I have had the same problem and it is an internal connector problem. Opening and closing aint easy and will take a little patience but it will work.
Good luck
SOURCE: set up of a Microsoft wireless keyboard & mouse
The devices probably came with a USB cable and a receiver, or just a USB equiped receiver, that you need to plug into your computer. Go ahead and plug the cable and receiver into the computer so that your wireless mouse and keyboard has a means to communicate with the computer. Next, Here is a website address where you can download drivers for your mouse and keyboard. You must first choose either mouse or keyboard, then the exact product and model, then the operating system, and finally the language. repeat the process for the other device (mouse or keyboard, whichever you did not choose first). Good Luck! And let me know if there are any further problems.
http://www.microsoft.com/hardware/mouseandkeyboard/Download.mspx
SOURCE: Microsoft Wireless Laser Mouse 6000 (Model 1052):
Normal
0
Go to Control Panel and click on the Mouse icon. Then
the mouse properties will appear showing the mouse buttons. Put the pointer on the left button and then go to the drop down and make sure the buttoon is set properly.
Hope this helps. Bud
SOURCE: Microsoft Wireless Laser Mouse and Keyboard Cut in and Out
I had the same problem wth the mouse. In desperation I moved the USB sender from the back of the PC to an unused USB port on my HP L1940T. Lo and behold, problem has gone away, but I suspect more by luck than judgement. David.
SOURCE: microsoft wireless laser keyboard 6000 v2.0 keyboard not working
You have to press the button on the receiver that is directly connected to the computer. While doing this, press the connect button both the mouse and the keyboard. I did this and now my keyboard is working, despite the battery indicator turning itself off a few seconds after I install it.
Hope this solves your problem.
cannot remove receiver from mouse
my stupied mouse is not working worth a flip
Is it a problem with the ports? Can you please post the exact error message it gives you if you get one please.
