I started to hit the gas getting ready to go up a hill and it just started to slow down.It was still running when i pulled over, shut it off, and it has not started since.
SOURCE: keeps blowing 15a efi fuse 1991 toyota pickup 2.2 re
there's a short somewhere causing that amperage to go up
SOURCE: fuel pump wont run and keep blowing a fuse in the front fuse box
The power wire to your fuel pump must be shorting out somewhere. Disconnect it and see if your fuse still blows. If not, then follow the wire all the way back to the fuel pump, and look for a bare spot. Good luck!
SOURCE: Will Not Start
It will not run without that fuse intact. There is a short in the circuit that must be fixed .
