Amana ARB1905C Bottom Freezer Refrigerator Logo
Posted on Apr 06, 2013
Need to replace light bulb in top of refrigerator and cannot remove cover model model bx21vl
My refrigerator WRS325FDAM04 needs new LED lights in both the freezer and refrigerator compartments; Could you guide me regarding what lights to buy and how to install them?
How to Change the Light Bulb on a Whirlpool Refrigerator
  1. Unplug the Whirlpool refrigerator from the electrical outlet.
  2. Locate the bulb on the inside of the Whirlpool refrigerator.
  3. Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. ...
  4. Unscrew the old light bulb.
  5. Screw in the new light bulb.
  6. Replace the light cover.
https://www.hunker.com/13409926/how-to-change-the-light-bulb-on-a-whirlpool-refrigerator
Led purchased from:
https://www.whirlpoolparts.com/Shop-For-Parts/a4b5c48d2135985/Model-WRS325FDAM04-Whirlpool-Refrigerator-Lighting-Light-Bulb-Parts
Were is the freezer light bulb ?
Good Afternoon Friend, that's a great question!
It appears that you would need to remove the light cover to reach the light bulb of your Frigidaire refrigerator (LFUS2613LF0). However, before doing so it is very important to unplug your refrigerator and wear gloves when replacing light bulb to avoid getting cut. Once you have removed the light cover you should be able to reach the light bulb and replace it with an equivalent bulb. Then you may replace light cover and plug in your refrigerator. Hope this helps!
How do you remove the light cover from amana refrigerator model arb2107?
I have an Amana AS12575GRB01, the cover to the light bulb on the fridge side is mounted on the top inside back right corner. Having problems removing it
Replace freezer bulb FRS26R4A
Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
To replace the light bulb on a side-by-side refrigerator you will need to follow the steps below:
1. Unplug refrigerator.
2. Wear gloves as protection against possible broken glass.
3. Remove light cover, if necessary.
4. Unscrew and replace old bulb with an appliance bulb of the same wattage.
5. Replace light cover, if necessary.
6. Remember to plug the refrigerator back in.
REPLACE LIGHT IN FRIDGE
- Unplug the refrigerator from the electrical outlet.
- Locate the bulb on the inside of the refrigerator.
- Remove the light cover. Usually these just snap off, but, on some models, they may need to be unscrewed. Use your screwdriver to unscrew the light cover retaining screws (if required).
- Unscrew the old light bulb.
- Screw in the new light bulb.
- Replace the light cover. Plug the refrigerator back in. Test your new light bulb.
Hope this helps, please rate if the solution was helpful, thanks!
2helpful
How to change bulb in fridge
To change a light bulb in the refrigerator, remove the plastic cover that covers the light bulb. This cover should just pop off by simply squeezing the cover gently. Look at the bulb to see how many watts it is and the type of bulb, you can buy a new bulb at any home improvement center. Insert the new light bulb and replace the cover. If the light on the refrigerator is not working after changing the bulb, unplug the refrigerator. Using a screwdriver, gently pop out the push-button collar on the inside side wall of the refrigerator. There will be two wires connected to the push button switch. Remove the two wires and replace the switch. You can purchase this part at any appliance repair center that carries parts. Make sure you write down the model and make of your refrigerator and take the information with you before attempting to purchase parts.
How do change the ref bulb on sharp ref model sj p43n - sl
Unplug the refrigerator. Remove the lamp cover by lifting up at the bottom of the cover. Then unscrew the old bulb and replace with an identical appliance bulb (Base E12, 240V, MAX 15W, T-20). This bulb is at the top center of the fridge.
The manual is available here: http://safemanuals.com/414159.php?ID=1286636&k=3942fa3f433aa4c53ff8bcb7d07ae8e8&q=SHARP%20SJ-P43N/P47N/43N/47N . You will need to review the fridge or enter a code to download the PDF. The light replacement instructions are on page 6.
I hope this helps.
1helpful
How to change light bulb in refrigerator
Step 2
Step 3
Step 4
Step 5
Step 6
Replace the light cover. Plug the Whirlpool refrigerator back in. Test your new light bulb.
Also note that the below can also work
Unplug refrigerator or disconnect power.
Slide the light bulb cover toward the back of the compartment to release it from the light assembly.
Replace burned-out bulb(s) with appliance light bulb(s) no greater than 40 watts.
Replace the light bulb cover by inserting the tabs on the cover into the liner holes on each side of light assembly. Slide the cover toward the front until it locks into place.
NOTE: Do not force the cover beyond its locking point; doing so may damage the light cover.
Plug in refrigerator or reconnect power.
To change the freezer light bulb:
NOTE: You may need to remove the upper freezer shelf or basket to access the light assembly.
The light bulb cover opens from the back. Firmly press forward on the notches in the back of the cover and pull down the cover.
Remove the cover and replace the burned-out bulb with an appliance bulb no greater than 40 watts.
Insert the front tabs of the cover into the liner and snap the back portion of the cover over the light assembly.
Good luck in applying the solution
5helpful
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
1helpful
Have an installed GE Microwave jvm1870 with a burned out oven bulb. Have replacement bulb but can not see how to get to the old bulb to replace it.
From the owner's manual:
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and EMO4000, replace the burned-out bulb with a 120 volt, 40-watt incandescent bulb (WB36X10003), available from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from your GE supplier.
To replace the bulb(s), first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the screw at the left edge of the light cover and push on the right edge of the cover to open.
Be sure the bulb(s) to be replaced are cool before removing.
After breaking the adhesive seal, remove the bulb by either gently turning (for models JVM1850, JNM1851, DVM1850 and EMO4000) or pulling straight out (for models JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the top grille by taking out the screws on top of the grille that hold it in place and sliding the grille to the left (opening the door makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located in the center of the top opening.
Remove the screw that secures the light cover and lift the cover off.
On some models, the light cover is located at the left of the top opening.
Lift the cover off.
Pinch the clips that hold the light socket in place and lift the socket out.
Remove the bulb from the light socket by pulling straight out.
Replace with the same size and type bulb, then replace the light socket and cover.
Replace the grille and screws.
Top Amana Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
