SOURCE: samsung rs2555sl ice maker trouble
how to replace the filter? the indicator light is on the front left side over dispersement h20/water
SOURCE: Ice maker water level too high
generally, there is a screw adjustment for this. usually, turning it clockwise sends more water during fill period (makes period longer). try it and adjust clockwise or counter-clockwise as necessary. Now finding the screw...try prying (or unscrewing) off the plastic cover over what appears to be the ice-maker unit (may also be on back side of frig.
SOURCE: Samsung Side by Side RS2544SL Freezer will not fill tray with water
Your problem may be in the water supply. Where the water connects to the back of the unit there is an electric valve, not a pump. The electric valve inlet orifice may be restricted, Shut off water supply and clean or replace the electric solenoid valve.
SOURCE: Freezer, Ice Maker and Water dispenser not working
it has to get down to the proper temperature after the reset the set point is -4 for the freezer and 38 for the refrigerator. the numbers shown o\n the digital display panel stands for the actual temperatures. When the compartmnet tempertures go down, so do the numbers on thge display panel, and finally they reach the set temperatures. Once the system is stabilized , the display tempoeratures are the set temperature.
SOURCE: SAMSUNG RS263OSH SIDE BY SIDE REFRIGERATOR DEFROSTED
sounds like a bad timer in the defrost cycle. Call a tech repairman
Hello Jim czyryca - From what you are describing if the ice maker is not making ice but is dispensing water, sounds like the refrigerator has a frozen water line, faulty ice maker valve or bad component that sends power to the ice maker valve when needed. The ice maker cycles internally to call for water so I strongly suggest contacting a professional to move forward accurately to assist with the repairs.
If your ice maker has stopped producing ice completely, try checking the following:
1. It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: If your ice maker has a small red plastic lever, lower it to lower the wire. If there's no plastic lever, simply lower the wire. In either case, the ice maker should begin producing ice again.
2. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
3. When was the last time the filter was changed? Most side-by-side filters are recommended to be change approximately every 6-9 months depending on your water usage and frequency. The ice maker fill tube may be blocked with ice or have a clogged water filter. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts!
4. Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
The ice
maker not working.-------------
Its the problem of water inlet valve. It's a
dual valve. This valve has two tubes in it. One for water dispenser and one
for ice maker chamber. The one side of valve is working, but other side of the
valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the
problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
