Epson L200 Original Continuous Ink Tank System cis Inkjet Printer And Scanner Logo
Anonymous Posted on Apr 06, 2013
Adjprog.exe for epson L200
Waste tank full problem
Albert Gamayo
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Apr 06, 2013
Albert Gamayo
Contributor
Level 1:
New Friend:
Answers
10
Questions
Helped
70122
Points
22
You can go to printerclinic.com and download a reseter of epson l200 or l100
Possible password: printerclinic.blogspot.com
Reseter of l100 and l200 are the same
Here's the instruction..
1.extract files
2.click the adjustment program
3.click the particular adjustment mode
4.check the three box on the left side then click initialization
5.then off the printer then on again
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 15, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13770
Points
10
teamtech
Level 2:
  • Epson Expert 108 Answers
  • Posted on Jul 05, 2014
teamtech
Epson Expert
Level 2:
Answers
108
Questions
0
Helped
322452
Points
547
Anonymous
Level 1:
New Friend:
  • Posted on Jun 26, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13770
Points
My epson px 660 shows this message: the printer's ink pads are nearing end of their service life. please contact epson support
How to reset epson l200?
Here the solution how to reset Epson printer.
Firstly go to the Epson L200 Reset/ Adjustment Utility.
Extract the Epson Resetter.zip file and locate the Adjprog.exe on your desktop , double click o the file and run.
Select the particular Adjustment Mode then choose the waste link pad counter from the maintenance tab.
now click on check tap and get the counter stats and then place check on the counter you want reset.
Click on initialize tap, to clear the counter.
A pop-up will appear to confirm that reset has been initiated adn complete , click ok to restart the printer.
Now click on check button to restted counter states.
Follow these steps and Reset your Epson printer to factory setting and read this article and solved your problem.
https://www.phladvisor.com/question/how-to-reset-epson-printer-to-factory-settings/
3helpful
2answers
Epson l200 servce required problem
Never had one of this series, but I have went through about 25 Epson printers and the message you refer to means your waste ink pad needs to be cleaned or replaced.
To get rid of the message do a search on "how to reset waste ink pad counter for Epson l200" and you will find a utility that does what you want.
2answers
Download adjprog.exe...
try to turn the printer on and then off, the same with the computer...
2answers
GIVE ME RESET KEY FOR EPSON L200
download l200 restter & run it for waste ink pad reset & use only epson geniun ink for noworry
34helpful
4answers
3helpful
GENERAL ERROR IN EPSON STYLUS T10
Probably the waste ink tank is full.Try to do this:
First of all download http://www.mediafire.com/?hzxbdhkzxv9.Extract to your C drive. Run indoreset.bat, then follow the instructions.
After that right click AdjProg and select properties. Go to compatibility and select Windows XP.
Click OK at the bottom then right Click AdjProg and select run as administrator (if you have this
option). When working accept the agreement and go to
1. Particular adjustment mode,
2. Then waste ink pad counter,
3. Click Check
4. Tick both boxes.
5. Then initialization.
6. Then it's done.
8helpful
4answers
Parts inside your printer are near the end of their service life.
i have a problem with my printer epson stylus C90. may i know what to do when parts of my printer are near the end of their life service.? how can i fix it?
Waste ink pad
to Reset Waste Ink Counter
  • RUN AdjProg.exe file Epson C90
  • choose Particular adjustment mode
  • select waste Ink pad counter
  • Klikinitialization
That’ all!
Top Epson Computers & Internet Experts
Rob Hill
Rob Hill
Ngoro
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
