The bottom hinge on the door. How do you use the door adjustments as the door wont shut smoothly because it is uneven.
SOURCE: Door hinge unaligned.
They are adjustable. It may have a cap over the top hing. If so it will either pop off with a flat blade screw driver. It it has a screw holding it, it will be in the center of the cap. When this is removed, there are three 1/4" head bolts on the fridge side of the hing. Loosen them, pull up on the door and re-tighten. The door should line up with the other door if the other door is aligned correctly. You may have to adjust both.
Please rate this solution if helpful. Thanks
SOURCE: iI have lost the middle hinge and top hinge for a
Notice the two web sites listed below. Either one of these sites will most likely have the part. I tried looking up the part number for you but you only show a parshall model number You will need a good model number before they can help. Here is where to find it.
http://www.vvapplianceparts.com/
http://www.appliancepartspros.com/
Please post a rateing if the solution is heplful. Thanks
SOURCE: I have an Westinghouse Silhouette
For best performance set the control at a mid point between OFF and HIGH.
The closer you set it to OFF the warmer the freezer.
The closer to the right HIGH the colder the freezer.
