P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Needed the manual to clarify a P1 error message. Figured how to fix the error P1 on my own. there are two drains on the unit, one is always open as an overflow drip, the other at bottom of unit has a plug. I opened the plug at the bottom of the unit, drained the water, and the P1 error code cleared.
