Question about KitchenAid KSM150PS Artisan Series Stand Mixer
Speed control on a K45 kitchenaid mixer only works on high speed.
My kitchenaid K45 mixer only works on high speed. What should I check to correct this so it will work with the slower speeds.
    Dedicated:
    Visited the website for 20 consecutive days.
  • KitchenAid Expert
  • 170 Answers
Hiya,
I am sorry to hear you are having trouble with your speed on your mixer.
I have added a link below for a help video on adjusting your speed on your mixer:
https://www.youtube.com/watch?v=bM3t46afGcc
I hope this helps you!!
Posted on Nov 20, 2019
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Kitchenaid K5A mixer 10 speed only runs on fast, no slow speed
Pull the back off and there will be two screws at the top of the Speed Control Plate and a 3rd screw at the bottom. Tighten the top two screws down. bakerboy49203@yahoo.com. Let me know if it works.
Posted on Mar 21, 2009
Anonymous
  • 143 Answers
SOURCE: grinding sounds and slower mixer speeds
It sounds like you may have a broken worm gear inside your mixer which is a common problem.It is a wearable part which transfers the power from the motor to the main drive. It may be chipped or damaged right now, and running it will cause more damage. Part number for the worm gear is W10112253. This does however require some know how to replace. Hope this helps
Thanks
Posted on Nov 22, 2009
reyjoshua07
Reynaldo Labaguis Jr.
  • 1157 Answers
SOURCE: I have a KitchenAid Mixer
Hi normangremms,
If your mixer does not run slow, it is often caused by the small circuit board in the unit that controls the speed. The easiest way to correct this issue is to check if it is malfunctioning. Here are additional step that you may use to solve the problem.
1. Turn off the unit.
2. With the back plate off, try to adjust the large black plate on the back of the speed control and see if you can regulate the speed better.
3. The plate has 2 screws on the top and one or two on the bottom, depending on the model about 3" square.
4. You can adjust the speeds if you turn the two screws on the top.
5. With the mixer off, start by turning them both the same amount of turns in the same direction and see how it affects the speeds. Start with 1/2 turn.
6. Be sure to keep track of the turns so you can return to the original start point if you have to. This will effect both the low and high speeds at the same time.
7. If you are going in the wrong direction, return to your start point and turn the opposite direction.
If this does not solve the problem, the circuit board is already malfunctioning and needs to be replaced.
Hope it helps.
Thank you for using FixYa.
Posted on May 12, 2011
LAURIE H
SOURCE: My Kitchenaid K45 mixer only runs at high speed.
I just fixed my 8 yo mixer! Would only work at highest speeds... first took it apart because it was making a terrible noise. Tthrough this site I figured out how to take it apart and replace the grease. Gears were in good shape, but a small nut fell out of the back while I was working on it. Finished putting it back together, found the spot where the nut belonged- holding the metal housing of the motor to the head. I turned it on and all I could get were the two highest speeds so I took the back panel off again and played with the bottom screw- it seems to adjust something on the wire that controls the speed. So take a philips screwdriver and adjust that screw and see if you get all the speeds back.
Posted on Dec 09, 2011
Hobart Kitchenaid parts for mixer model K45
The WACEM (We Actually Collect Electric Mixers) web site has a downloadable PDF of the "K5-A, K45 Original Service Manual" in the "files" section.
This can help you figure out what has gone wrong with yours.
Jan 10, 2018 | KitchenAid Food Mixers
How do you tilt the head back on this k45 model?
You will find a sliding lever on the side opposite the speed control. Pushing it toward the rear will unlock the head and allow it to be lifted.
If this does not work, you will need the Service Manual which shows the locking mechanism's action:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
Mar 16, 2015 | KitchenAid Mixer Parts - K45 Stand Mixer...
K45 kitchenaid mixer quits working under load? When beating egg whites it works great but try to cream butter and the beater stops.
It will be a broken or missing pin through a gear or the planetary or something wrong with the fuse gear. It should be easy enough to find but you will need to split the gearbox cases to check.
Sep 17, 2014 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid Hobart K45SS when set at 1-2 accelerates to high speed when making dough. How can I fix this?
Usually when the mixer runs only on high speed it is caused by the control plate adjusted incorrectly or the control plate spring unhooked. Remove the trim & end cover on the mixer and check the control plate spring, if unhooked, attach to bottom of the control plate and squeeze the spring end, also check the speed control plate screws,there are 3 screws on this plate, one at the bottom two at the top, see if adjusting the top screws slows your mixer down.
Next check the wiring of the mixer, Insure everything is wired correctly, to get wiring diagram go to the last page of the service manual. Here is a link to the service manual: http://lib.store.yahoo.net/lib/mendingshed/kitchenaidservicemanual.pdf
If neither of those fixes the problem it is probably a bad phase control board, or a shorted phase control board. With the line cord disconnected, pull the t-bar contacts to open and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run, if it operates at full speed the phase control is defective and needs to be replaced.
Use the service manual to aid you in taking apart the mixer, trouble shooting the problem and putting the mixer back together, based on the mixer only running at high speed some of the time I would assume it is the speed control phase board.
If you have any questions let me know.
Thank you,
Colleen
Customer Service
MendingShed.com
Apr 24, 2013 | KitchenAid Food Mixers
Kitchenaid K45 Mixer will only run at one speed, fast
is it a K45 or a K45SS? If it is a K45 you will have to replace the filters inside and probably the speed control plate, if it is a K45SS then you need a new phase control board. The K45 is pre 1978 and the K45SS is post 1978. Your information is correct on pre 1978 K45 models that the capacitor is bad, but it might be cheaper to go garage sale hunting and find a second machine as the parts are no longer made and having spares on hand may be a significant advantage in the future, also there are a great many of the K45SS parts that will also repair the K45 mixer so it may not be a practical solution. Watch ebay regularly for K45 parts, they come up every couple of months. On the parts diagram also look for the K5 diagram as it is identical to the K45, one is a 5 quart mixer and the other one is 4.5 quart, same parts same motor same everything.
Jan 30, 2013 | KitchenAid Food Mixers
My kitchenaid mixer run on high at all times
If your mixer only runs on high speed there are 3 things that can cause that. The first thing to check will be the speed control plate, Remove the trim and end cover on the mixer, the first thing you should see is the speed control plate, this has 3 screws on it, try adjusting the top two screws 1/4 turn, this should slow the mixer down, do not over tighten. Also check to see if the control plate spring is unhooked. If the spring is unhooked, attach to bottom of the control plate, and squeeze the spring end.
If this does not fix your mixer, check the wiring of the mixer, you can locate a wiring diagram on the last page of the service manual.
If the speed control plate is adjusted correctly and all the wiring is correct it will be your speed control phase board. You can test the speed control phase board to see if it is shorted. With the line cord disconnected, pull the t-b ar contacts to open, and insert a piece of paper between them so they cannot close. Reapply power-the mixer should just run or buzz trying to run. If it operates at full speed, teh phase control board is defective and needs to be replaced.
This will aid you in taking the mixer apart, troubleshooting and putting it back together, remember the wiring diagram is the very last page.
Thank you,
Colleen
Customer Service
MendingShed.com
800-339-9297
Jan 07, 2013 | KitchenAid K5SS Mixer Speed Control Plate...
HOW TO TEST A PHASE CONTROL BOARD ON KITCHENAID MIXER
I am sorry to say but only with a new one, about 30 bucks and five minutes of work, but if your mixer has any speeds working except only high (only high means it is the phase control board) then it is more likely the speed control board is bad rather than the phase board. Can you send is more info on what happened when the mixer started or stopped working. We can be of more help with more info
Oct 18, 2012 | KitchenAid K45SS Classic Stand Mixer
Which is the better mixer of these old models: K5A K5-A or K45 SS and what is the difference? KITCHENAID HOBART K5A K5-A 300 WATT MIXER and the KitchenAid Hobart Vintage K45 250 WATT. Thank you
Hello ajlina,
All of these are great home use units, all the attachments are interchangeable between these. The difference between these mixers is the K5 is a 5 quart mixer and the K45 is a 4.5 quart mixer. As I own both of them they are great in the kitchen and have the same durability.
Have any more questions please post to this thread and I will be happy to assist. Thank you for using FixYa.
Dec 09, 2010 | KitchenAid K45SS Classic Stand Mixer
I took a KitchenAid K45 apart to clean (made in
What everyone is forgetting or they just don't know is that...The K45 introduced by Hobart in 1962 and was replaced in 1978 by the K45SS are two completely different machines. With completely different wiring systems. The K45 is wired together with wire nuts and the K45SS used connectors on the Speed control switch. All of the websites posted above are for the K45SS (Stands for Solid State) The manual for he K45SS is easy to get from Kitchenaid as the mixer electronics did not change from it's introduction in 1978 to 1986 when Hobart sold the Kitchenaid division to Whirlpool. The K45 on the other hand is a product and property of Hobart NOT Whirlpool or the Kitchenaid division of Whirlpool. The K45 Manual ... well I just can't find one! They way wires are routed is totally different in the K45 from the K45SS so the diagram in the K45SS manual does not help. Also the brushes in the K45 were square not camphor-ed like they are in the K45SS so there is no right or wrong way to insert the brushes in a K45. Whereas; in the K45SS there are four ways to insert the brushes in their holder and three of them are wrong. The K45SS brushes go into a completely different brush holder than the K45. The K45SS is the same today in 2012 as it was in 1978. The K45 is the same only from 1962 when Hobart introduced it to 1978 when it was replaced with the new Solid State model. prior to 1962 it was the K4-A model and it was different entirely. So if the people asking for help say their mixer is a K45 we should be asking for clarification as to a K45 or a K45SS.
Mar 22, 2010 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM150PS Artisan Series Stand Mixer Logo
224 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
CJ C
CJ C
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
