SOURCE: i need wiring schematics for hilti te 905 avr
Wiring schematics can be found by Hilti 1-800 number but they probally will not help you. The 905 is programed to shut down for service every 40 hours plus 10 warning. Then in my case I am stuck with a 200 dollar bill to send the tool from Winnipeg to Montreal for reprograming. Its a joke in my situation and its on me from Hilti, what a good name but what a scam.
SOURCE: Hilti 905 avr starts up slow and uneven speed.
Some of them typically to start up slow. Less wear on the motor. Also make sure you're not using too much drop cord. No more than 100 ft 12/3. May be the brushes if you've had it for awhile. Please rate me
SOURCE: I have a Hilti TE 905 AVR the service light came
If you have the old type TE905, which is the one with the square type handle at the back, the service light will come on for 2 reasons. Either there is a tight bearing which will increase the amount of current used to work the machine. Or more common the carbon brushes need replacing. To reset the light, simply cure the problem.
If you have the newer type TE905 with the large “D” Type handle at the back. It gets a bit more complicated. The service light will come on for the same reasons as mentioned above, but it will also come on after 200 hours of use. It will continue to work for another 50 hours with the light on, then it will shut down completely. This is to ensure that it gets regular service. Once serviced or repaired, it will require resetting. To do this you with need a Hilti optical interface, a PC, and Hilti ODA Software. This is not available to the general public. If your Hilti is less Than 2 years old, call Hilti. They will pick it up, repair it, and send it back to you in 3 working days FREE OF CHARGE. If it is older than 2 years there will be a charge for the repairs.
I hope this helped you. Please leave feedback
