GHW9100LW2 - machine doesn`t take in fabric softener, it just fills with water (notice it at the end of the cycle of a wash). I`ve taken out the dispenser and cleaned the inside too. there`s no clogs whatsoever. Please help... thanks
The "FH" error can have several causes, so this can sometimes be a tricky problem to diagnose. Some of these error codes can also be erroneous. The first step to troubleshooting your problem should be to unplug the washer for at least 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main computer (or brain) of the washer. Sometimes this is all it takes to correct minor glitches. If your error code reappears following a reset, then you know you have a genuine problem. If the "FH" error persists, the following link explains what to do:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
Although, you may be correct in your assumption of a possible water inlet valve problem, I would recommend you read through the link provided and try to eliminate the easy things first. Check your installation for a possible siphoning issue, followed by a check of the drain pump. If those items check good, check the sediment screens in the water inlet valve. If you live in an area that has hard water, or if you use well water, the sediment screens can become clogged with deposits and debris. If you suspect a clogged inlet valve you can also remove it and thoroughly clean it in a 50/50 solution of water and distilled vinegar. Allow the inlet valve to soak in the solution for about half an hour and flush real well with clean water. Avoid submerging the solenoids and electrical connections, or getting them wet.
If you have questions along the way, or require additional assistance, please let me know. I hope you find this information helpful.
My washer flashes fhater a minute o washing and i cant get it to work and just wash my clothes! Its Making me very irritated and i just want to wash my clothes so i have some pants to ware!
