Model 795.76203.901 quiets after I do a manual defrost..not an acceptable noise level, especially for an appliance 2 years old
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
SOURCE: groaning noise on GE side by side refrigerator
Hello Michael,
Thanks for your question, I hope I can help some. My answer is long winded but full of good info.
The noise could be as the GE guy said refrigerant (gas) noise. If it is refrigerant noise it happens as the liquid refrigerant comes out of the tiny capillary tube and enters the evaporator (cooling) coil in the freezer. Along with the liquid coming through the capillary tube there often are gas pockets. The flow of the liquid and gas pockets into the evaporator coil cause strange sounds. If the noise you are hearing is this refrigerant noise, you should only hear the noise while the compressor is running and then only for a short time (1 to 2 minutes) after the compressor shuts off.
If the noise continues after that I do not think it is a refrigerant noise.
There are times when the compressor will not be running but the fan in the freezer will be running on this model. This is normal and working properly but if the noise is present when the freezer fan is running and the noise stops when the freezer fan stops, the likely cause will be the main board located in a square panel on the rear of the refrigerator above the compressor compartment. I know that sounds crazy but the main board can cause the freezer fan motor to make some really strange noises. Eventually the board will probably fail.
One other test would be for you to listen for the compressor to turn off, then if the noise is present after the compressor turns off, you would next unplug the refrigerator from the receptacle. If the noise continues with the refrigerator unplugged it must be refrigerant noise. If it stops, I am betting on a bad main board.
I tried to locate for you information on a material that Whirlpool and Frigidaire as well as some others use as a noise deaden-er that they wrap around where the capillary tube enters the evaporator. I was not successful in locating anything. I am sorry I could not find it.
supertechks
Please don't forget to rate me
SOURCE: Refrigerator/freezer is warm, fan is running.
The problem is the compressor isnt starting. The relay is probably ok. It should have 5yr warranty on the compressor. However if you purchase a Supco RC0810 start assist relay available at all appliance parts stores, it will start the compressor, however this is only a temp fix. But it should last till sears can put a new compressor in.
SOURCE: GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
SOURCE: Loud Freezer Motor noise
I don't usually buy the service plan but I did for this unit (hey it's gen 1). The service guy said he has seen this problem quite a bit and that LG created a new RCM board to fix it (part# BBR34917104). Apparently the OEM board didn't detect the ice build up on the fan motor very well. I had the new board installed two days ago and defrosted the freezer. So far so good, I'll post again if I have any further issues.
SOURCE: GE Profile Refrigerator (Model #20) w/freezer on the bottom
If the problem disappears (for a while) when the freezer reaches 32F, then I know what the problem is.
The GE Profile refrigerators (and likely other models as well) often don't defrost properly, especially in humid climates. So they can develop
ice buildup internally, especially if the air vents at the back of the freezer are
blocked by frozen food. Once that happens, that ice can
interfere with the cold air circulation booster fan that runs when the
freezer temperature is too warm. Then you get a LOUD buzzing noise
from the fan blades, as they bang into the ice.
The immediate "solution" is to be sure nothing blocks the air vents, and then to melt the ice that interferes with the
fan. You can turn the fridge off for a while (with the food removed so
it doesn't spoil), and/or get a hair dryer and heat the inside back of the
freezer, until the ice melts and falls away from the fan. (Just be careful
not to block the nozzle of the hair dryer, or it may burn out
from overheating!)
But
the ultimate solution is to buy another refrigerator, one that is NOT
a GE! And that makes me sad, because GE used to make GREAT
refrigerators. My last GE refrigerator is nearly 20 years old, and still works well, and it does so QUIETLY.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
