Battery is fully charged. No start response.
Ryobi Trimmers unscrew halfway down the shaft (so it fits in the box). If this gets loose, the trimmer will stop working. Simply tighten the connection between the upper and lower half.
SOURCE: I believe my Ryobi 12 VoltBattery Line trimmer need a new battery
First, check to see if the charger is working properly. To do this, recharge the battery for about 15 minutes. Then check to see if it now runs the trimmer. If so, then you have a bad battery. You can go on the WEB and find a replacement. These batteries or sensitive to heat and cold. When storing, try to place it in a comfortable environment. Sorry for your loss. If it still under warranty, check with the Co.
SOURCE: Ryobi 18v One+ battery won't hold a charge. I have
if it's both of them then i am thinking you have a faulty charger. i have seen mine do that, i got a new charger and it worked properly.
SOURCE: My Ryobi 700R "EZ" weedeater smokes excessively.
Check the fuel/oil mix ratio you are using. Some Ryobis use a 32:1 mix and some use a 40:1 mix. There isn't much difference there. To be on the safe side, if you machine is possibly running or tuned a little "lean" I would start off with about 4 oz/gallon oil to gas mix. Use synthetic 2-stroke oil also. Your machine will perform much better.
